Old 11-12-2003, 12:41 AM
KaosR_Eclipse_GsT KaosR_Eclipse_GsT is offline
Unhappy BooSt guage installation help
how Do u install a Mech. Boost guage?
cut the fuel pressure reg and tee tie it, somthing like that?
im lost please help
Old 11-12-2003, 01:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
Its better not to tee into the fuel pressure reg since a leak or broken hose/line there can cost you a motor. But most poeple use that. You can also use the BOV line, you just need 2 more feet of hose.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-12-2003, 02:20 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
Re: BooSt guage installation help
mines tapped into the hose coming of the intake manifold, is that what you call the fuel pressure hose?
-Agim
Old 11-12-2003, 02:28 AM
AF - Advisor
There are a few lines coming off the intake mani If you mean the small one on the far drivers side that goes to the Fuel Pressure Solenoid on the firewall and then to the Fuel Pressure Regulator on the end of the Fuel Rail, then yes, that could be called the fuel pressure hose.
Kevin Jewer
Old 11-12-2003, 01:03 PM
so just cut and tee the hose between the bov and the manifold?
(Diagram)
{BloW off Valve}-----[CUT and Tee to boost guage]-------{Manifold}
like that??
Old 11-13-2003, 02:48 AM
AF - Advisor
That would certainly work. If you have a gauge that also shows vacuum, that line will show the vac as well. HAve fun.
Kevin Jewer
Old 11-14-2003, 12:31 PM
that was easy...
thanks
Boost guage, no boost, weird numbers. Help! Thor06 Off-Topic 13 11-14-2005 05:19 PM
installing boost guage 2kBlkGTP Grand Prix 2 08-21-2004 05:53 PM
new boost gauge install help. scottsee Off-Topic 12 08-02-2004 10:37 PM
Guage Install...Help Needed B1SiR6A Let's get Technical! 7 07-20-2004 01:19 AM
air/fuel ratio guage, boost guage help jimmyfunk Off-Topic 5 05-29-2003 11:00 PM
