Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-11-2003, 07:51 PM
teglsturbo teglsturbo is offline
Where is the brake booster located????
Right now I have all my vacuum lines tapped from the FPR port (boost guage, boost controller, BOV, FMU, and Wastegate. Everything is working fine,but I heard it was a lot better to limit two or three vacuum lines to a port. I want to have the BOV and the Boost Cont. off of the brake booster and leave the rest on the FPR.
1. Where is the prake booster located?
2. Is there another vacuum source I could use besides the brake booster? If so,where is it located?
3. Any info or pictures would be greatly appreciated, Thank you
Old 11-11-2003, 08:18 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Where is the brake booster located????
I don't know about any other vaccume source but the brake booster is located behind the master cilinder (where u put in brake fluid). The booster is a big round object right behind the master cilinder. Good Luck.
Check out my car here My 91 Hatch
Old 11-11-2003, 08:23 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
You need to think about the functions and then group. I dont know if it makes a difference, but it does make sense. The brake booster should come off the back of the intake manifold and throught the firewall. It will be larger than the rest of the vac lines. The is a one way valve on the brake booster line, make sure you slip on the engine side of it. Trust me, if you don't your shit wont work right. This is how I have my stuff slip.
brake booster - BOV
throttle body vac - map sensor
wastegate, boost controller, gauge, and BTM off one
fuel pressure reg has its own
Old 11-12-2003, 03:43 PM
What specific line do you have these off of and where can I find it
97 Chevy Blazer/Brake Booster ezh10111 Problem Diagnosis 4 12-22-2012 07:46 PM
99 T&C Power Brake Booster Squeal? SlimJimRD Caravan | Voyager 1 06-29-2009 09:28 PM
power brake booster location tictiv Taurus | Taurus Wagon 4 10-18-2006 07:01 PM
Is it the brake booster? Blue_bags Pick-Up 5 06-09-2005 01:28 AM
