Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-11-2003, 07:29 PM
FRANK P FRANK P is offline
Unhappy '97 Grand Cherokee Problem ENGIN STALLS OBDII CODE P0351
I Have A 97 Jeep That Is My Wife's Car, About A Month Ago She Told Me That It Was Stalling On Her, I Drove It For A Week Nothing Happened, Gave Her Back The Jeek, It Started Again, Now It Does It Every Day. While Driving At Low Speeds It Will Just Die, You Stop It Will Restart And You Can Drive On Until It Happens Again Ten Minutes To 24 Hours, At Higher Speeds It Cuts Out Or Dies But Will Start Back On Its Own. A Friend Has An Obdii Code Reader And Hooked It Up To Jeep It Gave Off 1 Code Of P0351. I Asked For Help At Auto Supply, But They Could Not Tell What I Needed To Replace Or Do. Help!!!!!!
THANKS FOR THE CODE READING, Ignition Coil A Primary/Secondary Circuit Malfunction, BUT WHERE DO I GO FROM HERE? THE JEEP RUNS AND STALLS BUT WILL RESTART, IF THE COIL WAS BAD THERE WOULD NOT BE ANY SPARK TO START OR RUN?
Old 11-11-2003, 08:16 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Alldata says -- Ignition Coil A Primary/Secondary Circuit Malfunction
Old 11-12-2003, 02:56 PM
DIY Mechanic DIY Mechanic is offline
Could be the coil but check the ez stuff
Could be the coil but check the ez stuff.
Pickup coil, [in the distributer under the rotor], Spark Plugs, Distributer Cap & Rotor, Spark Plug Wires, Primary Coil, not much more to it than that actually.
After disconnecting the power to the pick up coil you can Ohm it out. The reading should be between 500-1200 ohms.
The Primary coil is the one on the passenger side front of the engine with the spark plug wire running from it to the middle of the distributor. The Pick up coil is in the distributer and has two small wires running to it.
I still think it will be spark plugs and/or Distributer Cap & Rotor
Old 11-14-2003, 06:53 PM
fdrepairshop fdrepairshop is offline
Send a message via AIM to fdrepairshop
Re: '97 Grand Cherokee Problem ENGIN STALLS OBDII CODE P0351
6 or 8 cyl?
if its the 8 cyl change the ign wires first, if the 6 cyl update the coil, change it it should come with the updated connector from the dealer, they changed it a bit, ive had that problem many times.
97 Grand Cherokee Laredo: Heating problem. Steve_jeep Grand Cherokee | Grand Cherokee SRT8 6 09-11-2010 08:15 PM
'97 grand cherokee laredo, stalling kat4jamie Grand Cherokee | Grand Cherokee SRT8 5 04-14-2009 10:52 AM
Phantom stall/tach drop '97 Grand Caravan Georgetime Caravan | Voyager 1 02-11-2009 02:21 PM
'97 Grand Cherokee stalls at start up Silver_88 Grand Cherokee | Grand Cherokee SRT8 7 05-27-2004 05:58 PM
