Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-09-2003, 06:46 PM
tigerbalm2424 tigerbalm2424 is offline
Trouble getting 1997 jimmy SLt into programmable mode(key fob)~
I purchased a used keyless transmitter and cannot get my jimmy into programmable mode. I tried this process; hold unlock button, ignition on/off/on/off, let off unlock button.
I tried this many times and it never worked. I looked into another way involving removing the bcm program fuse which my car does not have.
Are they any other ways to get it into this mode? What am i doing wrong?
Old 10-23-2004, 09:42 AM
Kelvin8r Kelvin8r is offline
Re: Trouble getting 1997 jimmy SLt into programmable mode(key fob)~
I had the exact problem. I finally found what you need to do. Look for the test plug underneath the dash. You need to find a good ground. Then connect a strand of wire between the top right terminal (I think it is identified with the letter A or B - you need the top right hand corner one) and your ground (screw or metal), you should hear the locks jump up and down. This will tell you that the vechicle is in program mode. When you get to this point I am not possitive but I am pretty sure that I had to hold down the lock & unlock buttons at the same time. Your original remote should already be programmed, but this will program up to 4 remotes.
2000 jimmy slt 4x4 rear running light out (Bulb is good) Lonnie 4x4slt Problem Diagnosis 1 02-11-2010 07:55 AM
1999 Jimmy SLT 4x4 module? cdn_pilot Jimmy 1 01-24-2010 04:05 PM
1997 Jimmy SLT Highway power is lacking. death2spam Jimmy 0 12-06-2004 06:15 AM
1997 jimmy slt block heater? do i have one? tigerbalm2424 Jimmy 2 03-02-2004 12:45 PM
1997 GMC Jimmy SLT Wheels... PiCtUrEMeRoLLiN Tires and Wheels 1 03-25-2003 08:28 AM
