Old 11-07-2003, 10:04 PM
blancoloco412 blancoloco412 is offline
steering knuckles with swap
I have a b17 swap on my 91 hatch. well they used the teg axles with no modifications to it. well i want bigger brakes do any of you know if they changed the steering knuckles to make the axles fit. all i know is that they changed something just to make the axle fit but am not sure if the steering axles is wat they changed help... cuz i want to put the ex knuckles with prelude rotors and accord caliper thing
Old 11-07-2003, 10:10 PM
91civicDXdude's Avatar
unless you have a Standard (STD) hatchback, then they wouldn't have to change the spindles for the axles to fit. B series axles will fit directly into Si/DX/LX/EX spindles with no problems, only a small ring on the inside of the hub, commonly called a dust seal, needs to be removed to prevent binding of the axle.
If they did however, change your spindles to integra ones, you will have much larger brakes than came on the car stock. Measure your rotors and come back with the results..
Old 11-07-2003, 10:46 PM
i believe they're the same rotos cuz i changed them myself and they looked the same as be4 the swap
Old 11-07-2003, 10:54 PM
r u able to use the teg spindles with civic rotors and calipers cuz i remeber seeing the teg rotors really bad like rusted out be4 they swapped my car witht the intention of doin the brake swap to but they didnt but dont know wat steering knuckles i have
Old 11-07-2003, 10:59 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
ok look, if u have an STD they changed your hubs, like dxdude said,
what model is your car?
Old 11-08-2003, 07:59 PM
si hatch
Old 11-08-2003, 08:06 PM
H4Bangin's Avatar
just call an ask what they changed
Where to buy steering knuckles TheSilentChamber '88 - '91 Civic | CRX | Wagon | Shuttlee 0 07-26-2004 05:51 PM
Help with steering knuckle!!! sageuvagony '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 06-20-2004 03:20 PM
Steering Knuckle repair landtoy80 C/K 2 04-29-2004 07:49 PM
Need Steering Knuckle, please blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 16 09-23-2003 01:16 PM
steering knuckles XxLuckyLisaxX '88 - '91 Civic | CRX | Wagon | Shuttlee 8 07-10-2003 02:37 AM
