Old 11-07-2003, 06:07 PM
mystizo916 mystizo916 is offline
lean fuel at top of second gear
hi, i've been modding my sister's 95 gsx automatic for a little while now and i stumbled across a problem. air/fuel goes lean during WOT at the top of second gear and continues to be lean through 3rd and up. the mods at the time were intake filter, upper IC pipe, 1g BOV, MSD 8mm plug wires, ngk iridium plugs, and removal of the restrictor in the boost control solenoid. there aren't any drastic changes in boost pressure during this problem. the air/fuel and boost gauges are both autometer. i thought that maybe the fuel pump was maxing out so i installed a 255 lph fuel pump and it didnt fix the problem. maybe im losing fuel pressure somehow but then why would it start going lean at the top of second? there aren't any boost leaks either (mitsu dealer checked it when my dad had them replace the air con compressor). i would greatly appreciate any thoughts on this problem and please guys, no shiet talkin on automatics, its my sister's car.
Old 11-08-2003, 01:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
Ho do you know its going lean, just from the blinky light guage? Those cant be trusted unless you have already datalogged to figure out which lights are "bad." Your best bet is to datalog and check for knock, or more accurately, timing since its a 2g. If there is anyone in your area that has a pocketlogger you could borrow that would be ideal. It costs about 300 to get into one yourself. Another option is to spend 100 bucks on a dyno pull if you have an AWD dyno, just for the sake of getting the WB graph. I guess the point I'm trying to make is that I'm not convinced you actually have a problem. With your mods you should be getting the stock AF ratio, and from the factory its very rich. You should be fine. If you do any further testing, be sure to post the results.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-08-2003, 03:32 PM
Re: lean fuel at top of second gear
thanx for the input. i guess i don't really know if it is going lean or not. im kind of confused as to why a lot of people buy a air/fuel gauge and end up not trusting it after they get a datalogger tho. i will try to find a shop in town that has a awd dyno. thanx again and i'll post my findings when i do some testing.
lean fuel bank 1, lean fuel bank 2 hotpursuit Sienna 4 03-07-2006 07:23 PM
Low fuel pressure lean fuel code 171 Mdonahue Grand Prix 0 06-09-2004 08:54 AM
burst of thrust/ hard shift when auto tranny shifts into second gear ERIKbronx Maintenance 6 04-22-2002 12:36 PM
Has anyone been able to go above 65 on second gear brandonf '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 34 04-19-2002 12:33 PM
rough second gear Aoshi1 Engine 10 11-05-2001 01:56 AM
