Old 11-07-2003, 03:50 PM
yaliny yaliny is offline
Question electrical question about taurus 2000
hi,
i've just purchased a 2000 Taurus SE. I have a couple of questions;
1. All of a sudden I realized that both of the brake signals and one of the rear lights are gone. And the transiver (remote) was gone a couple of days before that. I think one or two fuses might have gone.. Any suggestions or comments, like which fuses should I check, etc.
2. When the engine is off, the transmission stick is stuck at the P position. In order to be able to move that, I turn the ignition keys a little, get the stick to position N and only then be able to turn the engine on. And if I get it to P position, it does not move from there unless i turn the engine off and repeat the above process. Any ideas?
thanks in advance
yalin
Old 11-17-2003, 02:20 PM
mgrunsten mgrunsten is offline
Re: electrical question about taurus 2000
Originally Posted by yaliny
hi,
thanks in advance
yalin
I've had the same problems with my 2000 Taurus SE. I just found the problem with the brake lights. One of the wires coming out if the switch mounted on the brake pedal was broken. It must have broken from the back and forth action of the pedal Anyway I stripped the insulation back spliced a wire to the end with a terminal and replaced it. Now my brake lights work!!!
I'm going to work on the other problem now. I plan to remove the top plastic cover directly behind steering wheel. I suspect that some sort of cam has moved from its original position.
Hope that you find the same solution with your brake lights.
Mike G.
Old 11-17-2003, 04:18 PM
Re: Re: electrical question about taurus 2000
Mike G.
hi,
a couple of days ago i took the car to a dealer. they told me that "brake switch harness something" is broken and has to be replaced. After the replacement, brake lights and the sticky shifter were operational again. They charged me an hour for the diagnosis, another half an hour for replacement and about $30 for the so called harness.
hope this gives an idea for fixing your problem
regards,
yalin
Taurus transmission light and problems mikecorki Taurus | Taurus Wagon 4 06-01-2009 06:39 AM
Easy electrical question about grounding sageuvagony '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 06-03-2006 12:18 AM
Question about 1999-2000 Civic Si Coupe Rahab Car Buying Q&A 2 10-19-2003 02:31 AM
Questions about a 2000 Z28 Shortbus Camaro Discussions 10 09-09-2003 06:13 PM
questions about an 2000 hx duckhead4life Engineering/ Technical 9 01-12-2002 03:45 PM
