Old 11-07-2003, 12:41 AM
torch5253 torch5253 is offline
cleanin up a mess Zc motor swap
got this 91 hatch DX with Zc motor swap already done and trying to sort out the mess
ive read that I should use the PM7 ECU is that correct
what engine harness should be used ive heard that i should use the one from a SI Hatch is that true
it also has a hiccup on normal accell but not all the time has set a check engine light but i dont recall it right now.
Love my hatch Seeya
Old 11-07-2003, 12:46 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Re: cleanin up a mess Zc motor swap
You can use PM6, PG7, or PM7 ecus. I would recommend using the dx harness and modifying it to work with mpfi, it's not too tough of a wiring job. Get that code and post it up, and we can help you out better with that...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-08-2003, 09:24 PM
codes
the codes
code 6 coolant sensor
code 9 crank angle sensor/CYL sensor
code 16 fuel injector circuit-found a loose wire in a large white round connecter on top of the left strut tower could have set this code
main code is code 9 which i tested the sensor which check ok at the time but like i said the hiccup is very intermittant
im using the PG7 ECU and whats needed for the wiring alterations
hey thanks seeya
Old 11-09-2003, 12:17 AM
4GZChatch's Avatar
Re: codes
for the code 9, you prolly have the wires backwards, try switching them to see if this goes away. code 6, make sure the connector is on all the way, the wires are too short sometimes on the zc and need lengthened, or it puts some strain on the connector body. for the wiring alterations, the pg7 ecu will work exactly like the si pm6 ecu. check out the how-to at www.hybrid.honda-perf.org. I think that is the best one out there, it details all of the changes you have to make... Make sure you have your manual handy, and only reference the numbering set out by the diagrams for the 1.6L civic/crx.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
help please !! motor build question!! Derrick12556 Mirage 2 12-27-2009 05:31 AM
Lemans motor swap xxGriffonxx LeMans 4 10-27-2009 08:28 AM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
