Old 11-06-2003, 08:34 PM
Scott_bradley Scott_bradley is offline
1994 mustang gt
i've got a 94' mustang gt and i was wondering how low of gears should i go,but i still want to be able to run at least a 100. Im not for sure what is in it now but is very slow on take off. I cant chose between 373 or 410's im open 4 any suggestions. My friend has got a 95 gt and he can smoke me on takeoff and i want to change that.So tell me what i need 2 do to beat him. Ive also herd a chip was a good idea and i also herd it was a waste of money if your car was stock.
Old 11-06-2003, 09:26 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 1994 mustang gt
Chip; waste of money on a stock 5.0 motor.
Gears;
Auto, 3.73's minumal, or even 4.10's
Stick, 3.73's
I have 3.73 gears and can still run speeds of 120 mph.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-07-2003, 01:49 AM
12secv6stang 12secv6stang is offline
just a guess, you are in your teens so you should consider few things, 1) new gears will drastically affect gas mileage for he worse. be prepared to spend a little more extra money and visit the pump more often. 2) there are many more factors of getting beat off the line then just gears. are you both running the same trannies? how about tires? tread design, tire pressure, flexibility and the grip you get from your tires, also the width makes a big difference. if i were you (and had the money) get you a good soft tire with good grip, you wont get as many miles out of them especially if you roast them alot.BFG makes an excellent drag radial if you want to get serious or michelin pilots are a fairly good price tire for their performance.
remember: the size of your tire directly affects your rear end gears (since it is a ratio) so a smaller wider and softer tire would lower gears therefore better takeoff but not lower your top end as just a gear change would.
Old 11-07-2003, 01:48 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
why would you assume that scotty here is a teen? and what is wrong with being a teen? a lot of guys in my highschool were into restroing cars from the ground up.
furthermore, you are a liar - your post might be valid to some degree, but you have no credit on this forum.
scotty - the loss in fule efficiency relates to top speed per gear, i wouldn't worry about 3.73's though, with 4.10's i'm sure you could still pull 100.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 11-07-2003, 07:32 PM
stangfreak7 stangfreak7 is offline
Send a message via AIM to stangfreak7
I run a 3.55 gearing in my 94' mustang gt and i can smoke everyone of my boys off the line. They are running 3.73's and higher and i have no problem taking them off the line or even in a quarter mile.
Old 11-08-2003, 08:04 AM
you know if i wanted respect in this forum there are others ways for me to go about it. for one, why in the hell would anyone lie about a boosted V6 when saying i have a cobra would be easier (and what some people do) but thats not the way a fly. also there is nothing wrong with being a teen as i am one myself. but my assumption to his age was due to the fact he was interested in coming off the line quicker for the sole purpose of beating his friend. he didnt gift us with other reason he wanted takeoff so therefore i thought i would inform or refresh him of the idea that gear changes DO differ in mileage. were talking differences at 65 mph 3200rpm cruising vs 2700rpm. if you got a few miles of highway to go it will make a difference.
Old 11-08-2003, 10:59 AM
what ever, liar
free hypsi87!!
Dan's White Horse
Old 11-08-2003, 11:04 AM
Re: 1994 mustang gt
65 @3200? maybe in fourth!
between 3.55s and 3.73s @ 65mph we are talking about a differnce of less then 200rpms in fifth gear.
free hypsi87!!
Dan's White Horse
Old 11-08-2003, 01:17 PM
Re: Re: 1994 mustang gt
here you go just throwing numbers out again so i might as well make you look bad...
http://www.smokemup.com/auto_math/re...f3650898d615ce
http://www.smokemup.com/auto_math/tire_diameter.php
sign up... its free... and quit being such an ass
i used 265/50/15 in the formulas (its what i run on my stang) which end up with a tire diameter of 25.4 inches.
but like i said...the size of your tire drasticaly affects the gear ratio. and therefore should not be overlooked when a gear swap is wanted for example
if you run 265/50/15 @65mph running 3200rpm you are running 3.73s but if you run 255/40/15 @65mph running 3200rpm you are running 3.36s
Old 11-08-2003, 03:15 PM
alright, listen up -
you claimed 65 mph at 3200 rpms, which is a joke. with 25.6 inch tall tires, a transmition gear of .73 (the standard fifth) and a rear end ratio of 3.55 you are looking at 94 miles per hour at 3200 rpms.
with 3.73s and all else constant (that means unchanged) you would be cruzing at 89 mph. to bring this car with 3.73s to 94 mph again all you add is another 160 rpms.
100 mph with 3.73 gears is 3570 rpm on that same car.
here is my calculator: http://www.angelfire.com/fl/procrastination/rear.html
everything i have promised has held true, liar.
free hypsi87!!
Dan's White Horse
Old 11-09-2003, 10:21 PM
well am i right? did i make an ass out of myself?
free hypsi87!!
Dan's White Horse
Old 11-11-2003, 04:17 AM
Re: 1994 mustang gt
ACTUALLY YOU DID MAKE AN ASS OUT OF YOUR SELF BY TRYING TO MAKE ME LOOK BAD INSTEAD OF HELPING THIS GUY. I GAVE YOU ALL MY INFORMATION AND HOW I CAME TO MY CONCLUSIONS YET I AM STILL A LIAR
Old 11-11-2003, 11:08 AM
all i want to know if is my information is correct.
free hypsi87!!
Dan's White Horse
Old 11-11-2003, 12:49 PM
HiFlow5 0's Avatar
Stanger
Re: 1994 mustang gt
Dan, I got these #'s from an analyzer over on MW.
All #'s are with stock T-5 transmission gears ratios of .625 for years 85-93, and 25.6" tall tire.
3.55 gears, 3200 rpms = 100 mph in 5th gear.
3.73 gears, 3200 rpms = 96 mph in 5th gear.
3.73 gears, 100 mph = 3329 rpms in 5th gear.
Oh and don't worry about that shmuck anymore! Some how he was only banned for a day, but now he's toast!
-2013 Ford Flex
-1999 Ford F150
Old 11-11-2003, 01:48 PM
i was close enough, thanks highflow
free hypsi87!!
Dan's White Horse
'94 Mustang-Various Issues kitsuneboom Mustang Problem Diagnosis 1 05-11-2010 10:56 AM
1994 mustang gt mus5.0tang Classifieds 5 03-28-2005 06:16 PM
1994 Mustang A/C ! Need Expert Quick! drwiggle Mustang Talk 2 03-21-2005 08:29 AM
1994 Mustang GT Remote Keyless Entry Programming? speedster351 Mustang Talk 0 06-28-2004 03:24 PM
1994 Mustang Coupe *CHEAP MUST SELL* stang2004 Cars/Parts for Sale/Exchange 2 02-01-2004 02:27 PM
