Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-09-2010, 09:38 PM
kitsuneboom kitsuneboom is offline
'94 Mustang-Various Issues
I have a 94 Ford Mustang SRS (If that matters) that idles too high (about 2kRPM) upon start up. If you try to accelerate the vehicle before it's gotten, uh, stable? I guess, the RPM's drop dramatically (500 or less) and has died in the middle of traffic before due to this. It also backfires, and has a really hard time accelerating when starting from a dead standstill. What could cause this?
I've tried nothing because every time I go to any mechanic they treat me like I'm an idiot and tell me that my brand new brakes and oil could be the problem.
Old 05-11-2010, 10:56 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: '94 Mustang-Various Issues
First I'd look for a vacuum leak and proper operation of the Idle Air Control Valve. The IAC valve is located on the side of the intake plenum. A small tube from the air intake hose should branch off to this unit and it should be held on by 2 10mm bolts. It takes only a few minutes to take off. Sometimes they get dirty and they stick, causing high or low idles and stalling. Cleaning them may help. Replacing it might be necessary and Autozone should have a Duralast replacement around $80.
If the IAC valve is okay, then look and listen for a vacuum leak. Check all of the hoses for cracks.
While you're at it check your MAF sensor. It is in the intake tube just after the air filter. Clean it off with CRC MAF Cleaner. Gunk can build up on it giving the computer invalid information.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Tags
1994 , backfire , idle , mustang
