Old 11-06-2003, 02:55 PM
IvanBohannon IvanBohannon is offline
97 Civic with 17" rims has bouncy ride
I recently bought a 97 honda civic DX coupe as a daily driver. my main car is a 2003 350z. The honda has 83,000 miles.
The Honda tires needed replacing so i bought new tires and rims (17" rims) the tires are lower profile that what I would have preferred but i got a good deal.
Anyhow, the ride is bouncy and its feels very loose on the freeway. The steering is not stiff like on the 350z, and seriously sometimes i feel like the poor car is going just gunna shake apart on potholes.
I dont expect the car to handle like the 350z, but compared to my girlfriends 1996 honda civic EX (with 100k) , the ride is terrible.
I had the car inspected, inside and out when I bought it and the mechanics said everything was fine.
Im wondering if the larger tires and rims dont work with the stock suspension or if the stock suspension has just worn out and needs repair.
I don't want to lower the car or anything, and if I need to improve the suspension / replace stock supsension to support 17" rims i'd probably just go back and put 15" rims/tires back on the car.
http://f1.pg.photos.yahoo.com/ph/iva...da.jpg&.view=t
Any suggestions?
Old 11-06-2003, 03:23 PM
Blowncivic1320's Avatar
Blowncivic1320 Blowncivic1320 is offline
sounds like your suspension is just worn out. When I had my 95 it rode like that even with 17's with tires that were like 40's (REAL LOW PROFILE). My dad owns a bodyshop and said it would've needed new shocks, struts, springs, etc. I sold that car tho so that mite be it
-Andrew-
Old 11-06-2003, 10:19 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Don't know what to tell you, but I have two sets of 16s with good tires. I'd trade you a set for your 17s.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 11-06-2003, 10:23 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
likely to need suspension work either way... 15's or 17's the bigger wheels and tires may make the problem more obvious but if it is driving that bad there will still be problems with the 15's it proy needs shocks and suspension bushings at least.
LS1 RX-7 Zoom Zoom
Old 11-07-2003, 12:05 PM
93fury 93fury is offline
You definatly need to beef up your suspention a little. Probally a nice set of stiff springs and shocks. Sounds like one of your shocks blew and is sagging to that corner. If not that, if it has a factory sway bar, the bushing(s) could be shot.
Old 11-10-2003, 03:12 PM
sweet thanks for the ideas, ill take a look and see whats up. reading these forums is making me want to buy a turbo kit or engine swap, seems im missing out on all the fun! This is a dangerous place to visit. (for your wallet & free time)
http://f1.pg.photos.yahoo.com/ph/ivanbohannon/vwp?.dir=/Car&.dnm=97Honda.jpg&.view=t
Old 11-12-2003, 02:16 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
looks like a truck with 17s and no lowering...
anyway, whats the tire size spec.. like 205/40zr17? the thinner the tire (the 40 number is the height off the rim) the bouncier it will be. with very low profile tires the sidewalls have to be stiffer to bear the weight of the entire car as opposed to a much larger sidewall which can be very soft. i drove a 96 GS-R with 17s on 205/40zr17s and it had brand new shocks and it was a bouncier ride than my 90 GS with 15s on 195/50r15s with skunk2 2.5" lowering springs
94 Civic with constant high pitch humming in front end.... lizshouse88 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-19-2009 05:49 PM
FERRARİ F430(Fujimi Kit with Maisto rims and original ride height) eryxfrt Completed Projects / Gallery 3 08-14-2008 07:15 AM
New Civic Si 17" Rims Pictures. pimpmcdaddies '71-'87 Civic | CRX 1 10-18-2006 07:24 PM
94 Bravada Bouncy Ride derricknotorious Bravada 6 08-04-2005 07:25 PM
civic with 20 rim kkiepvvessau '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 08-14-2004 09:32 PM
