Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 11-06-2003, 01:32 PM   #1
slowfingerz
1995 325is blower resistor
If you have a blower fan that only works in the 4 position, the resistor needs replacing. I bought the resistor, have a service manual but CANNOT find the ^$#&#ing old resistor.
The manual says it's behind the glove box. I removed it and nothing there that looks like the resistor.
Any help out here?
slowfingerz is offline   Reply With Quote
Old 11-08-2003, 08:26 AM   #2
Filehorse 525i
For what it's worth, the resistor will be located in/on the Heat/AC duct work so the air stream can cool the resistors at lower fan speeds. Access to the one on my E30 was from the engine compartment. That may or may not be of any help on your 95 model.
Filehorse
Filehorse 525i is offline   Reply With Quote
Old 05-24-2004, 01:13 PM   #3
slowfingerz
Talking Motor Resistor
I found the blasted thing. It is accessed from the driver's side of the car. You need to remove the kick panel under the steering wheel. (couple of screws) . You can see it behind the center console but you have to get your head under the dash.
It is not to be accessed from behind the Glove compartment. Maybe that the case for RIGHT mounted steering wheel but no in the USA.
Once you find it yank out the old one & replace it with the new.
Blower Resistor Mounting Problem silverado_04 Silverado 3 08-09-2010 09:08 PM
'97 Grand Prix GT Blower Motor Resistor olopezm Grand Prix 11 06-10-2010 04:20 PM
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 08:32 PM
Where is the Blower Motor Relay / Blower Resistor located Cavycare Cavalier Problem Diagnosis 3 02-13-2007 08:22 PM
1989 bmw 325i blower motor resistor hammer182us 3 Series 1 10-30-2004 03:56 PM
