Old 11-06-2003, 11:23 AM
jrp1965 jrp1965 is offline
Thumbs down Dodge 3.0
Those who have 3.0 engines better test their engine when warm. Unplug wire to oil sensor. If it stop engine you are OK. If it does not stop you are heading for burn & lockup engine like I did with no warning. The sensors is suppose to cut off engine fuel injectors when no oil.
Old 11-06-2003, 12:22 PM
tazman tazman is offline
Re: Dodge 3.0
Good info but too late in my case. My daughter already blew the motor in the 89' Grand Caravan I gave her. Her friend did an oil change for her and stripped the new pan plug I put in 2 months earlier. He also used a hammer and screw driver to remove the filter instead of one of the three oil filter wrenches in the garage. Dumb kid!
Old 11-07-2003, 02:36 PM
sparky1 sparky1 is offline
Unhappy
Where is this sensor located?
Old 11-07-2003, 04:14 PM
Re: Dodge 3.0
It is near where the crankshaft pulley is,and where the pilpump is located.You can see oil sender unit is at. Hope this helps.
Old 11-08-2003, 01:16 PM
EVH5150 EVH5150 is offline
If the sensor is faulty then is that all you have to replace, or is there more to it? Thanks for the info, cant afford any more problems with mine, especially killing the engine.
91 mighty max 3.0 parting out Rip_Jeff Mighty Max 0 07-27-2010 06:04 PM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 01:11 AM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
How much is a 95 3.0L Voyager With 95k & Bad Tranny Worth? LightShifter Caravan | Voyager 2 05-30-2009 09:19 PM
