Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 11-06-2003, 08:32 AM
ktm9668 ktm9668 is offline
Speaker works sporadically--whats up with that?
Need some advise. My 91 525i Radio, left front speakers are cutting in & out making an occassional crackling sound. I dont think the speakers a blown because occassionally it plays great sound. I'm thinking it might be a ground wire, relay or something. Where should I start looking? Also how do you pull out the radio from the dash? Thanks for your help!!!
Old 11-07-2003, 11:02 PM
Cargorick Cargorick is offline
Have you found an answer through another source? My 93 525i is doing the exact same thing. Left front too! Hoping you found an answer for us.
Old 01-28-2004, 09:23 AM
martypeter martypeter is offline
Now that is wierd!! I've got a 1992 520 e34. I fitted a new head unit, 2 amps, 4 new speakers and a sub. I also have problems with the front left speaker crackling or not working. What's even stranger is the fact that the front speakers are running on new wire from one of the amps and this is connected to the head unit via phono leads. I put it down to a dodgy connection, but I have checked all of the connectors and they're fine.
Old 01-28-2004, 09:35 AM
Re: Speaker works sporadically--whats up with that?
I replaced the head unit with another OEM and it now works fine. Replaced nothing else. Weird is right......
Old 02-09-2004, 07:36 PM
Will308 Will308 is offline
Cargorick,
Which head unit are you referring to? The actual radio in the dash, the amp? I have a 1991 525i with the same problem. I though it might be a bad connection. Evidently it's a common problem.
Thanks,
Will
Old 02-10-2004, 07:17 PM
The radio in the dash was the problem. I did replace the amp 1st...but same problem. Put old amp back in and changed the radio. Problem fixed.
Rick
Blower smells like somethings melting/works sporadically net_kitten Taurus | Taurus Wagon 5 06-05-2006 08:08 PM
I have one speaker that works...now what? elementskater15 Car Audio 2 12-10-2005 05:04 PM
Speedometer Working Sporadically on 92 4Runner crary 4Runner/GX470 0 09-18-2005 01:48 PM
Gauges on 1996 Neon Work Sporadically broncovoice Neon | Plymouth Neon 1 03-31-2005 06:33 AM
S15 Conversion: All the sites dont work?Wad up with that? youngmanvr4 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 10 05-10-2004 06:46 PM
