Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-06-2003, 03:14 AM
foxfai's Avatar
foxfai foxfai is offline
Send a message via ICQ to foxfai
Unhappy Need Help on remote starter
I just recently bought a bulldog remote starter and entry system on for my 94 LS sedan. I am having a very hard time figuring out the way things wires. I am sure the intruction saids it pretty well, but i can't seems to locate the wire for the ignition and the door locks. I don't even know how many wires are there for the ignition switch ( 2 grounds or something )........can any one help?
Old 11-06-2003, 04:26 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
I feels sorry for you, the door lock wires are really hard to get to, they are burried behind alot of stuff on the left hand side , down by the pedals.
And the ignition has 2 wires I think, both positive, Its been awhile sense I installed a remote start, give me the model number of the alarm and i will try to help you further.
Old 11-06-2003, 11:42 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
While we're on the subject, how about being able to start it with out having to push on the clutch? I have an Omega Max, and they were gonna charge like 200 to do it at some car stereo place.
Old 11-07-2003, 01:05 AM
krazibimmer krazibimmer is offline
Send a message via AIM to krazibimmer
you have to bypass the clutch switch in order to use the remote start to start the car. the switch should be on top of the clutch pedal.
Old 11-07-2003, 02:50 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: Need Help on remote starter
i heard u if u snip the yellow wire it'll start w/o clutch.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 11-07-2003, 02:44 PM
foxfai's Avatar
I accually have a automatic, so it'll easier to wire. But i still haven't figure out how.......: (
Old 11-08-2003, 03:40 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Need Help on remote starter
It depends on what kind of switch it is. Some you can cut the wires, some you can just unplug the switch??? I prefer to use a relay and install a motion sensor so if the car takes off, the motion sensor would cut off the remote starter.
Old 11-08-2003, 03:42 PM
WIRE COLORS LOCATION
12 VOLTS CONSTANT WHT IGNITION HARNESS
IGNITION 1 BLK/YEL IGNITION HARNESS
IGNITION 2 WHT/BLK(95 ONLY) IGNITION HARNESS
ACCESSORY/HEATER BLOWER 1 YEL IGNITION HARNESS
STARTER BLK/WHT IGNITION HARNESS
PARKING LIGHTS RED/GRN(+) GRN CONN @ FUSE BX
DOMELIGHT LT GRN/RED(-) BLU CONN @FUSE BX
PWR DOOR LOCK BLU/WHT IN LARGER OF 2 GRY CONN
PWR DOOR UNLOCK BLU/RED BEHIND CRUISE MOD DRV KICK PANEL (TYPE B)
TACH SENSOR BLU @DISTRIB
BRAKE
GRN/WHT(+) @SWITCH ABOVE BRAKE PEDAL
HORN
BLU/RED(-) @RELAY ON LEFT SIDE OF FUSE BLOCK
Now, if you look at your fuse panel under the dash, there will be some empty spades, test them because you should fine the doorlocks, domelight, and other items since that's where the OEM alarm hooks into.
Old 11-10-2003, 12:22 AM
foxfai's Avatar
Thanks guys, This really help alot. Let you guys know when i got it installed, it's been very cold last few days, can't stay out....
Old 11-13-2003, 11:19 AM
rex1one's Avatar
rex1one rex1one is offline
Send a message via AIM to rex1one Send a message via Yahoo to rex1one
I've used a bullbog remote starter for a year now and love it (have the door/truck modules too). But my question is : where on the distributer do I wire in the tach sensor? (it's an electronic Distrib)
Right now the car just starts every 15 seconds until it see's that the engine's running.
Of you haven't broken it then you haven't gotten any use out've it.
Old 11-18-2003, 09:29 PM
Connect the tach. input wire from the remote starter to the wire that has AC voltage at the coil.
Old 11-25-2003, 05:24 PM
jeff tripz jeff tripz is offline
hey guys, i just got a remote start for my 98 civic... that whole color chart that sumone gave... can that b used as a guide for my car too or are they different?? sumone let me know please.. thanks in advance!
Old 11-25-2003, 10:19 PM
http://bulldogsecurity.com/New%20Wir...civic96-98.htm
Old 11-27-2003, 11:44 AM
thanks so much.. i appreciate it.. hopefully everything works out
Help with remote starter / alarm installation WMX267 Explorer | Explorer Sport Trac 6 11-10-2009 09:36 AM
Need Help! Possible starter? You tell me. Jerold Rodeo | Passport | MU 6 09-07-2004 04:21 AM
need a remote starter wickedplastikman Integra 10 01-29-2004 06:05 PM
Need help on starter problem jaime deal Caravan | Voyager 2 01-16-2004 06:05 PM
Need help with starter TLC Sentra | 200SX (USDM FWD) 1 04-16-2003 03:26 PM
