Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-01-2004, 04:14 PM
Jerold Jerold is offline
Need Help! Possible starter? You tell me.
I need some help. I have a 99 Isuzu Rodeo thats been giving me some problems. When I attempt to start it, it clicks, then clicks again, then it starts to turn over but may stop, then it either clicks again or just turns over and starts. Could this just be the starter. I play with the shifter sometimes because I though it wasn't starting because it wasnt completely in park. Also, does anyone know if replacing a starter is a big job or could I just do it myself. I replaced a starter in my jeep but it was an old one and it was pretty much just following the manual. Thanks
Jerry
Old 09-01-2004, 09:14 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Need Help! Possible starter? You tell me.
replacing your rodeo starter will be easier than a jeep starter. does sound likle thhat may be your problem
Old 09-02-2004, 09:46 AM
replacing the starter
Do you know where I can find information on how to change it myself? Like a step by step instruction or something? Thanks for your help.
Old 09-02-2004, 03:12 PM
tomlcollins tomlcollins is offline
If you need step by step instructions, buy a service manual. It shouldn't be much different from the old jeep you changed one out on. You disconnect the electrical connections and unbolt the thing, then do the reverse to put it back on. Don't forget to unhook the negative battery cable. If this sounds too complicated, I would suggest you take it to a mechanic.
Old 09-02-2004, 08:44 PM
1. disconect battery negative cable
2. crawl under vehicle with ratchet 14mm socket
and six inch extension
3. remove two bolts holding starter in place
pull starter down out of place
4. get out from under vehicle get a 12mm wrench
guess what's next. Yep disconnect power from
starter
Installation is reverse from removal
GOOD LUCK
Old 09-04-2004, 10:58 PM
danforth45's Avatar
danforth45 danforth45 is offline
you've never done this before have you fisheye? you even gave the size socket he needs, you sound just like a service manual!
97 Rodeo 4x4 3.2 SOHC V6
191k and running strong
31x10.50 Maxxis Buckshot
Manik grille guard
100w hella drining lights
Old 09-07-2004, 04:21 AM
txsoulfly txsoulfly is offline
Send a message via AIM to txsoulfly Send a message via Yahoo to txsoulfly
Here you go I just did this myself and it included one extra step in order to get to the starter.
Rodeo starter
Mando
1998 Rodeo S 3.2 3" sus lift, Dueler Revo's, Aisin hubs, and Aussie locker.
