Old 11-05-2003, 09:43 PM
crw crw is offline
86 Iroc Engine Problems
My brother in law has a 86 Iroc and his problem is that the engine dies when cold but will run when it's warmed up. He's changed just about all of the sensors. plugs, wires and even checked the IAC motor but still can't find the problem. Whats really strange is it will actually run fine if the air filter is off but as soon as he puts it back on it will die. I know it's an 8 cyl. but don't know what size. I've been trying to help him out, but we are both out of ideas. Is there anybody out there that can offer any help on this matter? Thank you for any information you can offer.
Old 11-10-2003, 06:55 PM
Clearly_Canadian Clearly_Canadian is offline
Send a message via MSN to Clearly_Canadian
Re: 86 Iroc Engine Problems
Try your cold start valve. It is a ninth injector in the middle of the runner tubes on the driver side. Atleast I think that is what it is...LOL
Clearly_Canadian
Old 11-11-2003, 02:17 PM
9ball 9ball is offline
You may want to check the coolant temperature sensor. If it isn't working properly, it makes the ECU think that the engine is already warm so it doesn't adjust the fuel mixture, however it'll run fine once warmed up.
88 Camaro Iroc engine dies shmy F-Body Problem Diagnosis 10 07-27-2008 01:54 PM
87 IROC engine problems EdgeZero87IROC Camaro Discussions 5 11-08-2005 01:27 AM
What's the difference 305 IROC engine and 305 truck engine? 33Chev Camaro Discussions 9 05-19-2005 12:07 AM
1989 Iroc Engine Swap? #24Jeff Gordon Fan Camaro Discussions 8 03-31-2005 08:57 AM
'86 IROC drivability problem Mr. Plinkit Camaro Discussions 1 12-20-2004 09:57 PM
