Old 11-05-2003, 08:33 PM
72GS 72GS is offline
72 Gs455
I am new to the forum. It is good to see that there are people to talk to to get tips on the Buick GS. I am restoring a 1972 Buick GS 455. Any advice on what to watch out for? I am redoing the motor right now.
Old 11-06-2003, 02:26 AM
Musclecarclub's Avatar
Musclecarclub Musclecarclub is offline
Re: 72 Gs455
Any specific questions? Restoring Buicks is definitely tougher than other GM A-bodies - mainly due to the lack of parts. However, both Yearone.com and Originalpartsgroup.com have Buick GS catalogs. I have ordered from both and have no complaints.
1971 Buick GS Convertible
350-4bbl w/ 3-speed Auto
1 of 599 made
Modifications: None - Totally stock!
Former owner of:
1969 Buick GS 400 Convertible
Modifications: 430 4bbl. V8 (from a '68 Riviera), Stage 1 spec Carb, headers, 2 1/2" exhaust, transmission shift kit, and column tachometer - to name a few ...
Old 11-14-2003, 11:26 PM
vbrpete vbrpete is offline
Doing the motor,eh?
DON'T CHEAP OUT ON THE OILING SYSTEM.
In case you're not aware,the only serious deficiency in the Buick V-8 is the lame oiling system.Don't even THINK of rebuilding without springing for a new front cover.The things get galled,being aluminum,and lose oil pressure because of it.The new cover,together with a standard volume oil pump cartridge,will help out big time.Also,contact Kenne-Bell,TA or Poston's about getting grooved main bearings for the crank-they oil far better than stock replacement bearings.Buicks have insanely large main bearing journals,and getting enough oil in them to prevent starvation is a big job.
I redid the 455 in my GSX four years ago and used every trick in the book.It rocked.Put a cam from TA in it,and even with the stock iron 4 barrel intake the thing would just obliterate anything it went up against.
Any other questions-let's have 'em.It's nice to talk Buick for a change(I own a Mustang shop-not a lot of Buicks going through it)
Old 12-25-2003, 11:19 PM
kratefan kratefan is offline
Re: 72 Gs455
Originally Posted by vbrpete
Doing the motor,eh?
Also, Buicks LOVE close tolerances! Don't build it loose.
Old 12-29-2003, 12:01 PM
a455gsx a455gsx is offline
I recommend you deal with a machine shop who specializes in Buick motors and also only buy engine parts from the reputable Buick vendors. You also need to know exactly what you want from your engine after the re-build. Is it for a driver, part-time race car, etc.
Some of the required items in my opinnion are:
A good double roller timing chain
3-angle value job (should use Stage 1 valves)
Hardened valve seats
Forged pistons
Arp hardware
New water pump
All components balanced (flywheel also if 4 speed)
Check oil pump and pump gear clearances carefully
The old Quadrajet carbs work great and are very easy to re-build. Make sure you don't use a 350 carb on a 455.
Choice of cam, headers, manifold, etc depends on what you plan to use the car for. For a daily driver I would recommend Lunati's stage 1 cam. It has decent power over the entire RPM range. I am running stock exhaust manifolds (machined by Greg Gessler) and an Edlebrock B4B aluminium intake manifold. Any Buick head can be upgraded to Stage 1 specs. Head porting makes a big difference if you plan on going to the track a lot.
Before doing the engine you should talk to the experts such as Mike from T/A performance. He knows his stuff as do all of the people who specialize in Buicks.
Brian
1970 GSX Stage 1 4-speed
1972 GS350
Old 12-30-2003, 02:09 PM
Re: 72 Gs455
Originally Posted by a455gsx
I
Brian
Great advice! Greg Gessler is one of the best Buick machinists around. His cars consistently win at Bowling Green.
Jeff
Value of Disassembled GS455 TurboGSR96 Skylark 8 02-03-2006 10:01 PM
Info about 70 GS455 St1 Conv antsgs Engineering/ Technical 6 05-23-2005 05:38 PM
1970 GS455 Slick Tire Size jeffbuick Engineering/ Technical 0 06-13-2004 01:28 PM
