Old 11-05-2003, 12:05 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
rattlin' valves
I have a 99 Z71 Silverado with a 5.3L and 77K miles. When I bought this truck used about a year ago w/45K on it, i installed a hypoertech 3 tuner. I noticed running regular gas after installing this made the valves rattle sometimes, so I started using 93 octane and have ever since. (yeah, $1.71/gal hurts sometimes) Anyhow, I recently had to replace the head gaskets, the passenger side one had a small hair-line crack in it and it was leaking coolant intot he oil. Ever since I had this done, the valves rattle when going uphill or when the truck is under a minor load, if I stomp on it it goes away. I un-installed the hypertech for about a day and then re-installed it, but nothing changed. Has anyone had this problem before, and what can I do to fix it? Its starting to annoy me VERY badly. Thanks lots
Old 11-06-2003, 11:05 PM
Tomahs7 Tomahs7 is offline
rattlin valves 2
I have a 1999 Z71 GMC 5.3 liter truck. When the hypertech 3 is installed in my truck and I give it gas without letting it downshift there is a bad rattle in my truck. It also is bad when going up hills. When it is not installed there is no problem. If anyone has a solution to the problem please let my know.
Thanks.
Tom
Old 11-07-2003, 11:36 AM
jeverett's Avatar
Re: rattlin valves 2
I've figured out what is causing them to rattle so badly. The fellow that installed my head gaskets said that he "may have" not set the timing back corrrectly. I'm not really fimiliar with these new vortec engines, but I havent seen a distributor on it. I know its got to have something like it, but I cant find it. I'd like to check the timing on it and see if it is off any. Do you check the timing on these engines like you do any other vehicle with a regular distributor, or is there some special way to do it?
Old 11-07-2003, 01:08 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: rattlin valves 2
There is no "adjustment" for timing on those engines...
If the distibutor was off, the SES light will illuminate and set a code.
To adjust the dist. you will need a Tech2 or other scan tool that is able to read camshaft offset...by turning the dist, the offset should be 0 degrees at 2000 rpm.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-09-2003, 02:57 PM
jeverett's Avatar
Re: rattlin' valves
But is it possible for the rattling of the valves to be caused by the mechanic not having it set correctly, or is it possible that he could have even changed it?
Old 11-09-2003, 03:32 PM
sc_customs's Avatar
sc_customs sc_customs is offline
Send a message via AIM to sc_customs Send a message via MSN to sc_customs
$1.71 for 93 octane?!#$ i want some. 91 octane here in town is $1.89
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
Old 11-11-2003, 08:09 AM
jeverett's Avatar
Re: rattlin' valves
93 octane has been as high as $1.96, but now its on what I guess you'd call, a downfall. It hasnt been below 1.70 in quite some while though. I can get it in Columbus, Georgia for i think..$1.60? That city is 45 miles away, but worth the trip!
Differences between PCV Valves CCMphysician General Discussion 5 01-13-2010 02:14 PM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 02:11 AM
95 Intrepid EGR Valve apmavis Intrepid 0 07-23-2009 06:20 PM
Polished Valve Cover for sale Axelthered05 Classifieds 0 06-22-2009 03:09 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 07:22 PM
