Go Back   Automotive Forums Car Chat > Toyota > IS200/IS300/IS350/Altezza
Old 11-04-2003, 10:20 PM
mo'sIS430 mo'sIS430 is offline
I've never done this before
I need to make my car faster and I was thinking about going Supercharger or Turbocharger....but I don't know which one is better for my car....so my question is, "in general", what would most tuners say would be better in attaining less wear and tear on my car....SC or TC? Money is not important...if anyone has any suggestions, they would be greatly appreciated.
Old 11-05-2003, 07:43 PM
IcESouL IcESouL is offline
i don't know much about cars but i'd go with a Turbocharger because there are alot more factory made cars with turbo's..
Old 01-07-2004, 12:16 AM
Redteam22003 Redteam22003 is offline
Sup
GO WITH THE S/C..ONLY 90RWHP BUT ITS ALOT SAFTER
GO WITH A TURBO WITH YOU WANT MORE HP...LIKE 400HP+++...BUT YOU KNOW WHAT WILL HAPPEN NEXTS..$$$ BECAUSE HEAD JOB..
GO HERE IF YOU WANNA KNOW MORE ABOUT TURBO,S/C...WWW.IS300.NET AND I WILL SEE YOU THERE
Old 01-07-2004, 12:18 AM
Re: Sup
GO WITH A TURBO IF YOU WANT MORE HP...LIKE 400HP+++...BUT YOU KNOW WHAT WILL HAPPEN NEXTS..$$$ BECAUSE HEAD JOB..
OOPS IVE RETYPE
Old 02-07-2004, 12:39 AM
Young_gee Young_gee is offline
Send a message via Yahoo to Young_gee
Re: I've never done this before
yo man, superchargers suck @ss go with turbos.
It's not how you stand by your car, it's how you race your car.
Old 06-09-2004, 06:59 PM
jimcyzfr1 jimcyzfr1 is offline
I would do your research, like somebody above said supercharger is lower hp output in kit form but you can do just about the same with both. turbo will have low end lag due to exhaust driven so rpm must go up for turbo to begin to spool hence TURBO LAG! s/c are belt driven off the engine and can be screw type or roots where boost comes on almost instantly. centrifical again is belt driven takes slightly longer to spool but still faster than almost all turbo set ups.
the other factor is the super charger is belt driven so you are using power to make power were as a turbo uses exhaust so your gains are not costing any power?
so it basically comes to how much power you want and the components that are avaliable. also have to remember the more boost the bigger the chances of blowing headgaskets, detonation etc. so you should really have the compression ratio dropped from normal vehicle 9.5-10.5:1
to 8.0-9.0:1 and use good head bolts and gaskets. same goes for nitrous use in large amounts anyway! good luck with whatever you chhose both very good power adders when done correctly!
Old 06-11-2004, 12:24 AM
legendtoo legendtoo is offline
Go with a turbo. We put 321 to the ground with my Stage I TBKO turbo....
[email protected]
I've never heard this one before! killermrob83 Caravan | Voyager 5 11-19-2007 09:24 AM
wow.. i've never seen this steering wheel before.. bionictony '88 - '91 Civic | CRX | Wagon | Shuttlee 5 10-27-2004 01:34 PM
I've never done this before . . . criticalbass Blazer 2 01-20-2004 01:42 PM
I've never seen this before. Does anybody know where I could get this? bah humbug Car Modeling 9 06-19-2003 10:55 PM
I've never seen this before... fastrThanU Street Racing 17 06-03-2002 02:53 AM
