Old 11-04-2003, 07:41 PM
m4dg33k m4dg33k is offline
Question 2000 cavalier - convert rear drum brakes to disc brakes
Does anyone know of a parts kit or a step by step set of instructions for converting rear drum brakes to disc brakes on a 2000 cavalier? Any info can help... Thanks.
Old 11-05-2003, 01:54 PM
sweetwhiteCAV sweetwhiteCAV is offline
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
www.stainlesssteelbrakes.com
they make a conversion kit...
Old 11-05-2003, 06:38 PM
Smile
Thanks, they do have a nice kit... less expensive than I thought.
One more question... 16" Aluminum Rims off a 95 Sebring 2 door, would these fit on a 2000 Cavalier 2 door?
Are there different 5 bolt patterns out there or all 5 bolt patterns are exactly the same - for small cars...
Could the rims be too wide (not diameter, the other dimension) for the Cavalier...
I know I would have to get lower profile tires but will I be able to steer decently without rubbing the tires on the wheel well?
Thanks.
Old 11-07-2003, 08:02 PM
no, there are different 5 bolt sizes, the cavalier has a 5 X 100mm. so, if that wheel is 5X100 then it'll fit...
Old 11-10-2003, 08:47 PM
Thanks. I will have to measure the rims...
Old 11-16-2003, 11:04 AM
04_CaV!! 04_CaV!! is offline
Re: 2000 cavalier - convert rear drum brakes to disc brakes
you should be measuring the distance of the lug holes not the rim. If the rims are indeed 5x100mm you then also have to worry about the offset of the rims. If the offset of the new rims are not correct you will not only potentally rub the inner strut but the outter wheel well. If the offset is not right you will also have problems with your wheel bearings not so far in the distance future, it will wear them out and not only will you have to replace the spindal but you potentally are risking your life with acctuall wheel seperation. I suggest that you call a pro and ask them the correct offset for you app. of your Sebring rims and if you can acctully use them on the cav.
86 626 Rear Drums to Disc Brakes dkoug 626/Capella/Capella Wagon 0 10-02-2007 02:42 PM
upgrade rear drums to disc brakes wpatters1229 Grand Cherokee | Grand Cherokee SRT8 1 03-16-2006 03:11 AM
'87 Camry rear drum to disc brakes conversion maatsi Camry/Camry Hybrid/Vista 3 11-14-2005 02:08 AM
converting rear drums to discs smokindog Camaro Discussions 3 06-30-2003 09:44 PM
