Old 11-03-2003, 07:42 PM
gilkman gilkman is offline
parking/ebrake will not engage
I have a 2002 tahoe, 4dr, 4wd, LT, autoride.
the ebrake will not engage (failed inspection). I looked at the adjuster under the drivers side by the frame and it appears to be at it tightest setting already. the dealer wants to replace the pads and charge a lot of $$. It has 32k miles on it. I can't imagine they would have worn out by now. Anyone else run into this? any suggestions?
thanks
Old 11-04-2003, 06:22 PM
bustedratchet bustedratchet is offline
Re: parking/ebrake will not engage
Is that 4 wheel disc ? If it is your parking brake shoes are probably shot or way out of adjustment.
Old 11-04-2003, 09:02 PM
yes it is 4 wheel disc. are the ebrake shoes hard to replace? I am familiar with replacing the pads on my Jeep wrangler.
Old 12-10-2003, 06:27 PM
Joe_T Joe_T is offline
I just adjusted my Tahoe's parking brake, it was a simple matter of getting the pads into the right place, flicking the 'self adjuster' nob and getting the drum nice and tight (so that it's difficult to go back on) and then I bled the system and made sure the rears had a 'light' drag when rotating it by hand.
because I was new to drums the whole process took about 8 hours and I needed to borrow a friend for the bleeding
'01 BMW 330i
fuckin slow!
'98 Infiniti QX4
stock as a rock
'98 Tahoe 2dr 4WD sport
X5 HID's, 265/75-16 BFG's, stock motor
'93 Mustang LX coupe
heads/cam/intake + stock 302 shortblock
11.95 @ 114 best so far all motor
Old 12-13-2003, 07:09 AM
99ssconv 99ssconv is offline
with 32k miles it will be covered under factory warranty due to service bulletin is out for new design retainer that keeps the shoes from moving and contacting the rotors causing premature failure.
a/c not working 02' pa clutch will not engage climate control prob also crnwb Park Avenue 1 07-17-2010 10:47 PM
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
Starter will not engage 2000 Buick Century Borden7 Century 2 06-06-2004 08:06 PM
2002 Envoy Starter and Fuel Pump will not Engage msbailey Envoy 1 05-09-2004 08:50 PM
325i will not engage starter morser 3 Series 2 12-29-2003 05:19 PM
