Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 02-22-2004, 11:02 AM
msbailey msbailey is offline
2002 Envoy Starter and Fuel Pump will not Engage
I recently purchased a 02 Envoy wrecked in the front. I have fixed the damage but the Envoy will not start. Everything else works perfect, it seems as if the starter and fuel pump will not engage. Could this be some kind of theft system shut off. Any info will be helpful. Thanks.
Old 05-09-2004, 08:50 PM
MIKECORPSINC MIKECORPSINC is offline
Re: 2002 Envoy Starter and Fuel Pump will not Engage
Chech Your Ignition, There Is A Black Box, Play With The Wires To See If It Will Start. This Is A Common Problem With Gm Cars. If The Accident Caused The Driver To Hit The Steeringwheel Hard Enough, There May Be Ignition Damage.
Also, Play With The Shift Lever, Maybe The Neutral Safety Switch Is Mislocated, Shiftlinkage Bent Or Something Like That.
Also, Alot Of Vehicles Are Programed To Shut The Fuelpump Off On Impace To Prevent Fuel From Comming Out And Catching Fire. Try Disconnecting The Battery, Leave It Like That For A While With The +&- Touching To Short The Comp. It May Reset And You Wimt Have To Take It In To Have It Reset. About An Hour On That Idea. It Usually Works When I Do It In My Shop.
