Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-03-2003, 10:39 AM
jeffsmith49 jeffsmith49 is offline
Fan motor not working
I have a 92 SL2. Fan motor is not coming on. Have replaced sensor, still not working. It doesn't come on even when I turn on the AC. Have jumped it directly to battery, and fan runs. Fan blade is very hard to tur, but does turn when 12V DC is put to it. Any ideas on what to check next?
Old 11-04-2003, 01:49 PM
xr6vn9z xr6vn9z is offline
Hi Jeff. I had the same problem. I had to replace the fan motor myself.
Old 11-10-2003, 02:31 PM
Re: Fan motor not working
Did your fan motor run when you jumped it directly from the battery? Mine will, just not when it is supposed to run from the sensor. Let me know. I can replace the fan motor for $43.00. I am just about to send it into the shop, which kills me. I'll wait to hear from you. If yours ran and turned hard, I'll give the motor replacement a shot.---Jeff
Old 11-17-2003, 01:12 PM
owl owl is offline
Jeff,
I am having the same problem...when i am stuck in traffic the temp goes sky high..i read that if you turn on the ac it should take care of the problem...well i noticed the fan does not turn on when the ac is started..i assume i need to replace the cooling fan motor...i am trying to keep costs down as i am getting rid of the car soon. any idea if it could be something else???
Old 11-17-2003, 05:00 PM
Originally Posted by owl
Jeff,
I am told the same thing about turning on the a/c. I don't get mine to come on either----but like I said it will run if I pull it out and jump it directly to the battery. Blades turn very stiffly, but seem to run ok with direct jump. I will replace it in two weeks---luckily don't have to drive car but a few miles--so it doesn't get a chance to heat up. Fan assembly is not that hard to remove, then you have to r/r the motor itself.
Old 11-17-2003, 06:16 PM
owl owl is offline
Re: Re: Fan motor not working
Well i bought a new motor for 25.00 and replaced it. works like a charm. the only thing of note for those of you planning to install it yourself is not to tighten the bolt onto the fan too tight or it will freeze up. That may be the problem with your blade not turning very well.
Old 12-10-2003, 01:12 PM
I finally gave in and pulled out the old fan motor. The shaft would barely turn and was really grinding. Headed the warnings about not overtightening the LH nut for fan blade. End of problem. Fan kicks on at 3/4 on temp guage and cools her down very quickly!!!
Old 08-17-2006, 10:37 PM
d-i-yer d-i-yer is offline
Where'd you get your fan for $25 bucks? One guy said $43 but not where from and one guy said $50-NAPA-15 minutes. Was your's OEM and required no modifications?
Thanks
Old 08-19-2006, 09:39 AM
PlayStation3 PlayStation3 is offline
ok welcome to the forum but please as you can read this post has not had a respone in like 3 years so it is a dead post.
Old 08-21-2006, 10:38 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Thread closed due to age
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Fan Motor not working on low and low/medium reaves31 Cavalier Problem Diagnosis 6 06-15-2008 12:18 PM
Radiator fan motor not working Nene27 Grand Cherokee | Grand Cherokee SRT8 1 06-27-2007 06:53 PM
Fan motor only works on high still after resistor block change Mojoman Sebring | Sebring Coupe | Convertible 3 10-26-2004 11:07 PM
Main cooling fan does not work. Why? Riki Tiki Thunderbird 1 02-23-2004 11:53 PM
Closed Thread
