Old 11-03-2003, 07:10 AM
Tugger Tugger is offline
Unhappy Cherokee "Bobble" in Steering. Help!!
My 90 cherokee has a top-heavy feel in the steering. Other Cherokees I had seem to get same problem. Mechanic has put in new steering box but I don't think that is the problem. New tie rod ends, dampener have helped but slight "bobble-head" feel is still there. Any suggestions are appreciated.
Old 11-05-2003, 04:42 PM
Den3221 Den3221 is offline
I have a 91 Cherokee with a similar problem. It "chatters" between 55-60 mph, but doesn't seem to do it for speeds higher or lower than that. My mechanic didn't know what it was, said everything looked fine. So I replaced some of the sway bushings in the front end b/c they had rotted out and that seemed to have tightened her up a little, but she still "chatters". The aftermarket lift and larger tires on my cherokee probably don't help the front end either.
Anyway, if you get it fixed I would be interested to know, this way I can see if it fixes my problem.
Old 11-09-2003, 09:00 AM
fdrepairshop fdrepairshop is offline
Send a message via AIM to fdrepairshop
Re: Cherokee "Bobble" in Steering. Help!!
heheh you need a viscous coupling in the transfer case. 231j or 242j same thing. parts are expensive for it. wish all you people could come to my shop, all i do is jeeps. hehe well thats most likely your problem there, pretty much you'll notice it on u-turns.
'01 Grand Cherokee Limited Power Steering Help churrieta Grand Cherokee | Grand Cherokee SRT8 0 08-01-2008 09:53 PM
89 Cherokee Power Steering Box Murphster05 Cherokee 3 07-21-2007 08:20 PM
1990 Cherokee Power Steering Pump KirkLipscomb Cherokee 5 02-19-2007 08:32 AM
1999 Cherokee Sport Steering Trouble r82148v Cherokee 7 07-21-2006 10:52 AM
cherokee tilt steering adjustment jimbojones Cherokee 5 02-01-2004 07:03 PM
