Old 11-02-2003, 10:53 PM
shane157 shane157 is offline
2000 Cavalier idle problem O2 sensor?
I have a 2000 Cavalier LS, the idle jumps up and down for 750 - 2000 RPM, if it runs very long the exhaust/manifold will get extremely hot. I was told the the air/fuel mixture is wrong and that is why the exhaust is so hot. If I let it run for about 5-7 minutes and put it in gear to move it, sometimes it will back fire and die. I have a generic OBD2 code reader and all it tells me is that the idle is too high, also a local mechanic said he got the same code. Is it an O2 or other sensor, I believe this car has a couple O2 sensors. Any tests I can do?
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
96 z24 cavalier idle problem 2.4 msca Cavalier Problem Diagnosis 14 03-29-2009 09:36 PM
2000 Cavalier Idle Surging High and Low zbban1 Cavalier Problem Diagnosis 3 03-26-2009 12:11 PM
96 cavalier idle problems heavychevy76 Cavalier 4 09-08-2008 06:10 PM
97 Cavalier idle problem tjn357 Cavalier Problem Diagnosis 0 12-13-2007 03:38 PM
