Old 11-02-2003, 11:05 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
DPFI TO MPFI Help please
Hey all, I am helping a friend with a dx put on an mpfi swap, and it won't start. I have double checked the wiring, it turns over, but there is no spark at the spark plugs. Any ideas? Also, he decided to use an Si engine harness, and, since the large round connector on the driver's side is different, rewired the Si harness into the DX connector. However, there is one blue wire that doesn't match up with any other wire on the DX connector, anyone know what this goes to? Everything is hooked up, including the grounds, and there is just no spark.... I would really appreciate any help you all could offer!!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 11-03-2003, 12:59 AM
MaXXuS's Avatar
MaXXuS MaXXuS is offline
Unfortunantly you can't plug the Si wire-harness into the dx's, the wiring is to different between the two, I was going to do this until I found out it is a no-no. You need to put the DX wire harness back in and re-wire it.
Old 11-03-2003, 01:03 AM
4GZChatch's Avatar
Re: DPFI TO MPFI Help please
crap, that sux. is there no possibility of rewiring it? or does it take the whole dash harness?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-03-2003, 01:10 AM
MaXXuS's Avatar
Re: Re: DPFI TO MPFI Help please
You could swap out the whole dash harness, but whats the point, thats waaaaaaaay too much work compared to just re-wiring. Is it a 4dr or a hatch? If it is a hatch then it might be a possibility, because the wiring harness will fit & not be cut short, but on a four door, no way no how. Too be honest with you, re-wiring is a lot easier, just make sure you take your time and soldier your connections.
Old 11-03-2003, 01:23 AM
4GZChatch's Avatar
Re: Re: Re: DPFI TO MPFI Help please
it is a crx, to be precise. Just for reference, what could be done to use the Si harness? I'll tell him to go hit a junkyard for a DX harness...
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-05-2003, 05:08 PM
4GZChatch's Avatar
Re: Re: Re: Re: DPFI TO MPFI Help please
bump... any help?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-10-2003, 08:47 PM
4GZChatch's Avatar
Re: Re: Re: Re: Re: DPFI TO MPFI Help please
OK, I've narrowed it down to the problem being the smaller 6-pin connector that is at the strut tower. Has anyone used the Si harness? Can anyone tell me what wires need to be swapped over to the DX harness and which ones can be pulled from the Si side of the harness? I have already pulled out the ones to the TDC/Cyl, Pos. Sensor. What others need moved? Anybody? This kid needs his car, and I would really like to be the one to get it running!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-11-2003, 12:19 PM
travagliante's Avatar
travagliante travagliante is offline
The pin connector above the strut tower i believe needs to have the wires changed. If you just plug it in it will throw out the wrong codes.
Old 11-11-2003, 12:51 PM
4GZChatch's Avatar
do you know what the order should be? right now, it looks like most of the colors match up, but I don't know what to do with the ones that are totally different... Any ideas? Anybody used this before?
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-11-2003, 01:38 PM
Ok the colors shouldnt match up since you are using the si harness. Am i correct? Um im at work but i have the order at home ill post back im about 4 hours with the answer. Youll need to take out the wires and redo them so they will work properly. Ill see you later
Old 11-12-2003, 02:13 AM
4GZChatch's Avatar
You got that pin order? I could really do with that asap!!! Thanks!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 11-21-2003, 02:34 AM
CRX-Fluffy's Avatar
CRX-Fluffy CRX-Fluffy is offline
Send a message via AIM to CRX-Fluffy
Use these links bro:
http://www.geocities.com/c_rexboy/mpfi.html
http://www.4thgenerationcivic.com/how-to's/mpfi_conversion.htm
http://www.angelfire.com/d20/h....html
http://pub161.ezboard.com/fbse...topic
Old 11-21-2003, 09:32 PM
Gringo003 Gringo003 is offline
are you using a dx engine or si engine you also need to change dizzys the dx dizzy wont work and if you just modify your dx harness its only like 13 wires to run its pretty simple look at the past posts there is a bunch of shit on this swap
Old 11-21-2003, 10:44 PM
4GZChatch's Avatar
Yeah, I got it working fine. This is a really old thread, and the wiring is all done and it's fine. Thanks for the input, though, guys.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
3300 v6 not firing right help please!!! hyorinmaru Grand AM 8 07-31-2009 04:02 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 04:27 PM
dpfi/mpfi d15 any !HELP! appreciated dropemhard '88 - '91 Civic | CRX | Wagon | Shuttlee 13 01-22-2005 10:16 PM
DPFI to MPFI Help!!! >>> Almost Done... Help me get there! turblown '88 - '91 Civic | CRX | Wagon | Shuttlee 6 06-19-2004 12:49 AM
Re: MPFI ---> DPFI Conversion help??? 1989_cash_eater '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-27-2004 10:18 PM
