Old 12-16-2004, 04:03 PM
dropemhard dropemhard is offline
dpfi/mpfi d15 any !HELP! appreciated
Currently:
This is the problems I am in, its a canadian 1990 civic dx with i/h/e/nology wires/newplugs/cap and rotor and a top end slipping clutch. The car gives off a STRONG gas odor and alot of black smoke, there is also soot on the muffler. I believe I have mpfi and a si ecu(which may explain why I have a check engine light on), but every1 tells me dx's have dpfi. Heres why I believe mpfi: the guy b4 me had a si engine (D16) in the car, i think he didnt change the ecu or mpfi on my car when he re-swapped in the d15. MY battery dies VERY fast and i think its cuz of a rigged up tachometer. ALSO my friend owns a stock crx with a rebuilt d15 and a GOOD clutch and his car feels way better than mine and he only has two injectors.
Here are my questions:
1. How can I tell the mpfi vs the dpfi apart.
2. How can I tell the dx ecu apart from the si ecu?
3. Why does my car run so rich?
4. Why and how can i fix the "check engine light"?
5. My tachometer stays on after i turn the car off and it may suck up my battery is this true?
6. Does the mpfi and si ecu on my dx engine make less hp than a dpfi dx ecu?
7. How can i fix the gas ordor and the black smoke?
8. did my comments and question confuse any one ?
please email and thing relavant to this to [email protected]
comments suggestions help or hate mail will be read
Old 12-16-2004, 04:12 PM
Synthetic_6 Synthetic_6 is offline
Re: dpfi/mpfi d15 any !HELP! appreciated
Originally Posted by dropemhard
Currently:
DPFI looks black, kind of rounded, says DPFI on the cover. MPFI says MPFI, it's a lot bigger, metal, there is a lot more plastic on the DPFI. They look a LOT different. Try looking both up on Ebaymotors.com..you will see pictures. You can look up the ECU model number online or post it here. Your ecu is located under the carpeting on the passenger side. Also, if you have MPFI you need an SI ecu, if you have DPFI you need the DPFI ECU..you can't mix and match these. Also if you have MPFI you need to make sure that you have a Injector Resistor Box. But first things first..verify if your DPFI or MPFI..then we will know what's wrong.
Old 12-16-2004, 05:26 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
After you find out what you got (DPFI or MPFI) then pull back the capet on the passenger side footwell and look at how many times your ecu blinks. Tell us how many times and we can tell you whats wrong.
88 civic dx
Old 12-16-2004, 10:05 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
http://www.cardomain.com/memberpage/602150/3
that is DPFI... the mpfi looks like the newer honda layout
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 12-16-2004, 10:46 PM
arodg25's Avatar
arodg25 arodg25 is offline
A mpfi ecu will have a sticker on one of the sides with a number on it saying something like xxxxx-pm6-xxxx and a dpfi will have a xxxxx-pm5-xxxx. You cannot run a dpfi with a mpfi computer and vice versa.
mabey but i've never seen anyone hook up a tach that stupidly before. it should be hooked up to a power wire on the ignition or somewhere.
Hell no!!!! a mpfi on a dx engine will kill a true dx anyday.
there is no quick answer for these. sorry. mabey 02 sensor, blown head gasket?
Old 12-17-2004, 11:44 AM
2ndb18's Avatar
Do a fricken search.
88 civic dx
Old 01-22-2005, 04:22 PM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
We have a pm6 ecu after all. So How is it that we have 4 injectors instead of 2 ?; is this causing us to run RICH????. We will be taking the tach off of the car today and also post after.
Old 01-22-2005, 07:20 PM
What does it mean when my ecu blinkes 10 times?
WE uninstalled the tachometer it had 4 wires: red, green, white & black, the green one was spliced into the DIST cap?? (i dunno if its the dist cap)(i believe that this is where the tach read the RPM's from). The red wire was installed with another red wire into a the fuse box(i dunno where the other red wire came from maybe it was the white wire). Finally the black wire was just hangin there and I yanked it out. POST your reply
Old 01-22-2005, 07:52 PM
Josh95cx Josh95cx is offline
Code 10 -Intake air temp its the white sensor in the intake manifold on the drivers side. It go's into the side of the intake.
Old 01-22-2005, 08:19 PM
ok i found the code for 10 blinks on the ecu:diagnosis = bad Intake Air Temp. Sensor what this means to me = WTF??!?!?! i need help!
Old 01-22-2005, 08:23 PM
dis regard the above post i didnt see you post "JOSH95CX"
This is my Q: do i need to replace the sensor or what ? What does a bad connection mean, closed/open circuit?
Old 01-22-2005, 08:26 PM
i have an aftermarket intake, and the sensor isnt on there... so wtf? also what if it is completely removed for the harness ? ? (i dont think it is tho)
Old 01-22-2005, 09:12 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
the iat is on the manifold
Team Lonely Drivers
Old 01-22-2005, 09:16 PM
Re: Re: dpfi/mpfi d15 any !HELP! appreciated
if it is still on the harness hook it up to your air intake tube close to your throttle boby. it it was cut off you would most likely have a check engine light. follow the harness and you might find it. thats why i wouldnt buy a modded car or let someone do the work. most people get lazy or cheap and do it half ass
btw this therad is pretty old you should have just started a new one...
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
