Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 11-02-2003, 09:48 PM
Patrat Patrat is offline
Question MT gear indicator switch?
Hi all, first post here.
I am installing a remote start in my 1987 5 speed 944 (base model)
I am trying to find the sensor that allows the computer to know what gear the car is in, so that I can use a neutral safety switch (so remote start only works when in Neutral)
My haynes manual does not list any such sensor in the wiring diagrams, but it seems it must be there because of the intelligent shift light. The light never comes on in neutral or 5th, so it must have a switch.... right?
Any help is much appreciated.
Old 11-03-2003, 08:04 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: MT gear indicator switch?
It doesn't HAVE to be there. There could be something else it is doing in order to get that reading. What I do is make sure that I hook up the parking brake wire then install a motion sensor. The sensor is the kind used on alarms that trigger when the car is being jacked up to either have the wheels stolen or be towed. That way, if you leave it in a gear then remote start it, the motion sensor will pick up the movement then stall the car.
To date, never seen a MT vehicle with a neutral switch other than a motorcycle.
Gear Indicator Broken mymaxlvsattn C/K 3 07-18-2004 07:14 AM
Changing the Combo/turn indicator Switch Ichimonban Accord/TSX/Accord Hybrid 0 05-16-2004 07:09 PM
Gear Indicator stuck on Drive darreld Alero 0 01-27-2004 11:13 AM
89 Camry, Turn Indicator Switch does not return after turning pawnpace Camry/Camry Hybrid/Vista 1 01-14-2004 06:52 PM
Looking for Gear Indicator device Rx7-84 RX-7 1 12-21-2003 10:34 PM
