Old 11-02-2003, 08:25 PM
TheRainman TheRainman is offline
rocker-to-valve gap / valve ticking
Greetings..
As a new member, I did brief search to see if I could find an answer to my problem, but I had no luck, so hear goes.
I have a '94 Grand Prix with 3.1L V6 (type M engine I believe, the later of the 2 types, T and M). I am experiencing loud ticking coming from my engine compartment. It sounded like it was originating from inside the valve cover, so I decided to remove it and have a look at my rockers and pushrods and such.
I noticed that on several of my un-compressed valves, there was quite a large gap between my rocker and valve (or rocker and pushrod..). I could wiggle the rockers quite a bit, in other words. I do not have a feeler gauge set, but I would estimate about 1/4 inch gap.
I can't imagine this is normal. I checked the bolts that hold the rocker, and they were all tight. I removed some of the pushrods and they looked alright (not bent), nor did they look worn on either end.
Is there any way I can adjust my rocker arm downward to help take up the slack, or is this being caused by a different problem altogether?
MUCH thanks to any who offer some words of wisdom.
Cheers...
Old 11-03-2003, 08:31 PM
Well... I posted this identical question on clubgp.com forums, and a few indicated that it may be lifter colapse. It was also indicated that the rockers cannot be adjusted, so lifter colapse would be the only likely source of a changed dimension resulting in an increased gap between my pushrod / valves.
Does anyone here agree with this notion?
Many thanks..
Old 11-06-2003, 05:47 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: rocker-to-valve gap / valve ticking
I agreew with that notion..as does my dad who I showed this thread to. But that's a lot of collapsed lifters! The only way to tell is to take the intake off and check. Good luck!
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Passenger side ticking/rattle noise ktl4974 Problem Diagnosis 9 08-29-2009 08:31 PM
Rocker Arm Cover (aka Valve cover) b1gfella Cherokee 8 01-31-2004 06:10 PM
Valve Gaps 1SickZC '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-22-2004 04:36 PM
94 gsr valve gap???? d_fl8ted1 Integra 0 12-10-2003 08:24 AM
