Old 01-23-2004, 07:13 PM
b1gfella b1gfella is offline
Question Rocker Arm Cover (aka Valve cover)
After completing the cooling system revamp today I was stoked to work on the Jeep some more. I have had a small oil leak problem for a long time and noticed it again today. I think it may be coming from the "rocker arm" cover and running down the engine. I say this because the oil doesn't seem to be driping directly from anything but a crossmember and the plate. It kinda moves around. I've never seriously looked at it but after being in the engine compartment for three days (I went slow on the work I did so it was right the first time).
Anyway, here is my question...is a leak from this source something that happens? If so the book I have says that cover has a gasket seal built on it. This is a first for me as all the other cars I've owned had a gasket you had to buy under there and replace. Is this true? Well I imagine it is, but I just wanted some background or experiences before I plan to do this. Do you just pull the cover, clean everything, then run a bead of silicon gasket and put it back down? Any gotchas to look out for? it seems like a pretty simple procedure...
Thanks!
Old 01-23-2004, 07:39 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
The valve cover gasket is prone to leak just because of old age.
Just take out all the bolts, pull the cover off, clean the mating surface on the cover and head very thoroughly, clean and paint the old valve cover if you plan on reusing it, apply some rtv to a new valve cover gasket, and bolt it back on. Its really easy and should only take about 5-10 minutes if you arent gonna repaint.
Old 01-23-2004, 08:11 PM
Re: Rocker Arm Cover (aka Valve cover)
So there is a gasket you need to buy for this piece? the manual makes it sound as if there is one built in to the cover...
Old 01-23-2004, 08:31 PM
Just go to Napa or where ever and ask for a valve cover gasket for your jeep. Its should be about $6.
Old 01-23-2004, 08:41 PM
Do you know what the torque spec is for the bolts when I reinstall them? The manual states to torque to spec but fails to say what that is!
John Harris
http://www.electra225.com
"Problems are just solutions in work clothes"
Old 01-23-2004, 08:48 PM
There isn't a torque spec cause its just a valve cover. Just make sure the bolts are secure. I just used an opposite cross pattern like when tightening lug nuts on a wheel.
Old 01-23-2004, 11:03 PM
I found and checked my other book (I have a chiltons and a Haynes with a jeep shop manual on the way) and it had a torque spec of 55 inch-pounds or 6 newton-meters...It does not sound like alot but when I did valve cover gaskets in the past they never were very tight or you ended up breaking the seal...
John Harris
Old 01-25-2004, 11:33 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Do not overtighten the bolts or you will crack the cover and or get a leak at the gasket. Try a 1/4 inch ratchet and highten about as much force as you would use with a screwdriver.
Old 01-31-2004, 06:10 PM
Its impossible to get an exact torque because the gasket will compress as you tighten. You just have to use good judgement when tightening. I certainly used A LOT more than 55in/lbs, yet I have no cracked cover, no torn gasket, and not even a drop of oil has came out since. Its all about the guesstimation. But there is such a thing as too tight, dont get me wrong.
Polished Valve Cover for sale Axelthered05 Classifieds 0 06-22-2009 02:09 PM
Aftermarket Rocker Arms, Valve Lash? Highbeamz Grand Prix 2 11-12-2008 07:06 AM
rocker arms,valves and lifters 96 monte carlo bsr518 Monte Carlo 0 03-12-2008 12:30 PM
rocker arm / adjust valves ttaylor61 Windstar 9 11-19-2007 09:14 PM
Beige rear privacy cover (aka cargo cover) ldmpsu General Discussion 1 05-10-2004 01:08 PM
