Old 11-02-2003, 02:59 AM
elvinKee elvinKee is offline
Send a message via ICQ to elvinKee
attaching the part
jus bought a tamiya evo 6 road edition,i had tried to use tamiya cement
to attach the bumper,side skirt and rear bumper,the problem is,it won't
very stick on(easy to separate)and had gap between the body to bumper.do i hav to use super glue?do i hav to use putty to fill the gap??what kind of putty?
and 1 more question abt my fairlady350z...about to attach the window to the body,do i hav to use super glue to attach them??cuz i used cement,it had gap on the up side of the window(the same problem as attachin the bumper to body)
Old 11-02-2003, 09:28 AM
simdel1's Avatar
simdel1 simdel1 is offline
im not sure about the panel gaps. its unusual for tamiya if there is a fit problem. you could try filing or sanding the contact areas until it fits right. perhaps the glue from previous atempts to attach it have built up on the contact area. next time use masking tape or elastic bands to hold the bumper onto the body while the glue sets.
with regards to the 350z, again im suprised that there is a gap, but please DO NOT use super glue. it will fog the glass and make it look simply terrible.
Simon
Old 11-02-2003, 01:15 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: attaching the part
If the contact surface is too small and the bond is not so strong, apply a piece of plastic sheet on the back of the bumper and body. You can use either styrene glue or super glue. To fill the gap, you can use superglue as a gap filler, or use solvent putty, such as Tamiya basic putty, Squadron or Testor.
To attach clear parts, don't use superglue or it'll fog up the part so badly, and you end up sanding and polishing to get rid of it. Use 2-part epoxy glue.
Hiroaki Fukuda
Old 11-02-2003, 09:14 PM
DJ RaYgU's Avatar
DJ RaYgU DJ RaYgU is offline
Re: Re: attaching the part
For the clear parts, is it alrite to use modeling cement?
Old 11-02-2003, 09:18 PM
Bryan_831's Avatar
Bryan_831 Bryan_831 is offline
Send a message via AIM to Bryan_831 Send a message via Yahoo to Bryan_831
Re: Re: Re: attaching the part
hirofkd: really? i always thought that 2-part epoxy glue is like super glue and will fog up clear parts.
Will Selleys Bolt Fast 5-Minutes 2-Part Epoxy (with a tube of resin, and a tube of hardener) work and not fog clear parts?
Special Thanks to Desi Gangsta for the great Avatar
Current Project
Porsche 911 (996) Carrera with Putty Mods
Next Project
Nissan Skyline R34 in White, with SAS C-West Hood
"Some people look good from far.
On closer inspection, they are far from good."
Old 11-03-2003, 01:53 AM
simdel1's Avatar
look here...i found it in the FAQ
http://www.automotiveforums.com/vbul...992#post578992
Simon
