Old 11-01-2003, 09:45 PM
87jeep 87jeep is offline
Help finding a fuse!
My windshield wipers just stopped working the other day on my 87 cherokee, and I'm thinking it's a blown fuse. I found all the fuses under the drivers side dash, but I can only find the rear wipers fuse, not the front wipers. Anyone know where I should look?
Thanks
Old 11-01-2003, 10:26 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
Passenger side of the engine bay.
Old 11-02-2003, 02:27 PM
XJnick XJnick is offline
Actually,
The front wipers are on a circuit breaker, not a fuse, which is located at the bottom of the fuse block found inside the Jeep by the clutch and/or brake pedal.
-Nick
1988 Cherokee Pioneer, 410,016 miles!
1997 TJ Wrangler
Old 01-30-2004, 01:28 AM
GunnyJeep GunnyJeep is offline
On the lower dash panel below the steering column is the control box for the wipers it is a couple of inches wide about 4 inches long and 1/2 inch thick, it will be black and velcro'ed to the panel (just feel til you find it) that is normally the most common problem with wipers.
Old 06-07-2005, 03:10 AM
kds87xj kds87xj is offline
Send a message via AIM to kds87xj Send a message via MSN to kds87xj
Re: Help finding a fuse!
Originally Posted by XJnick
Actually,
-Nick
My '87 had the same problem, and this is correct, it is below the fuses. On mine, the contacts had actually rusted off over the years...good luck!
Old 06-11-2005, 07:21 AM
Stick89's Avatar
Stick89 Stick89 is offline
Send a message via Yahoo to Stick89
Actually,
-Nick
That would be the module for the INTERMITTANT wiper system,it can be discoed but will not effect the wipers,you just won't have the intermittant part...If the module fails,I'm told it is a DEALER ONLY item
and we all know that means BIG $$$$$$$$
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
Old 06-11-2005, 11:11 PM
Stick89's Avatar
OK I am officially stoopid this post is the one I ment to qoute...What Gunny is talking about is the intermitant wiper module.Disco that and see if the front wipers work...Pulled mine and that was MY problem.
Now for the REAR WIPER...1st you gotta remove the inner panel on the back hatch there should be a relay to the left(looking at the hatch from
inside the vehicle)of the wiper motor...could also be the problem..got anybody who knows how to check the relay?If the relay is good,then more than likely the motor is toast...
Apologies to XJNICK
Cannot find fuse panel, wipers not working HELP! faithmd Grand Cherokee | Grand Cherokee SRT8 2 03-05-2005 11:54 AM
help find fuse for front turning signals (97) rob1005 Corolla/Matrix/Voltz 1 08-07-2004 12:07 AM
cant find fuse box nicksastar MR2/MR-S 1 04-05-2004 11:36 AM
where to find fuse box in 98 lumina ltz kathy123 Lumina 1 02-27-2004 11:23 PM
