Old 11-01-2003, 05:25 PM
geofstan geofstan is offline
Question Fast Idle 1988 Honda Accord LX
I am hoping someone can tell me how to adjust my fast idle (if this is possible) or what to check for faults.
Old 11-02-2003, 08:49 PM
20HondAccord02 20HondAccord02 is offline
Send a message via AIM to 20HondAccord02
What exactly is the car doing? Is is surging? Is it stalling?
no, i dont have the accord anymore... just didnt feel like setting up a new account.
2005 Acura RSX Type-S
1983 Honda Civic 1300FE 5 speed Hatchback
1970 Dodge Challenger 440 R/T convertible(under construction)
Old 11-02-2003, 09:54 PM
Re: Fast Idle 1988 Honda Accord LX
The car is running fine, its when i start the engine from cold the engine idles at around 1000 rev as if the fast idle isn't working properly or needs adjusting.As you can tell i am a beginner to all this.
Old 11-04-2003, 02:40 PM
Has the car always done this? How old is the car, how long have you had it and how many miles?
Old 11-04-2003, 03:11 PM
It worked fine until i changed the pcv valve (which had nothing left inside it) and corrected the timing. it's an 1988 i've had it 2 months and 225,000 km
Old 11-04-2003, 04:14 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Try unplugging the Battery for a few minutes then reconnect. Start your car (Do NOT press the gas pedal to rev the engine) Let your car naturally idle for about 5-7 minutes once you hear it idle down to around 500-700 RPM's turn it off and wait a few minutes and try it again.
If it stays at a constant 1000 RPMS you may want to adjust your idle and or your throttle cable. If it is just doing it when it starts up and then idles down, you may have a bad Cold Start Sensor (Located underneath the Throttle Body). You will also want to check your coolant levels to ensure that you have plenty of coolant. If it is staggering or surging up and down and up and down, you probabaly have a vaccum line undone (see the underside of your hood for directions).
Honestly most cars idle kinda high upon starting them, then when they warm up they idle down. If it goes up past 1000 RPMS then ideally you may have a potential problem..
Peace
~J
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 11-05-2003, 12:14 PM
Is the car caurberated? I had an '88 Accord LX and it was. in that case, there is a fast idle valve on the carb. I dont remember if the cover is black plastic or brass but it is round with either 3 or for screws around itholdign it together. you should be abled to take that apart and there is a spring inside. I am not sure if youcan buy another one but you may cal a dealership to find out. I had this prob with mine and i had a parts car that i got the spring out of. Not sure if this will solve the prob but it helped me but my prob was actually the fact that the car didnt want to idle while in gear. From my knowledge, it will naturally reve to 900 rpm, maybe 1000 rpm for a minute before the car warms up. as long as the car idles steady at about 700 to 750 while in park or neutral and doesnt hesitate when you tap the gas pedal, it should be fine. My 02 accord idles up like that when it starts cold, as does my Integra with 220,000 miles.
Old 08-17-2017, 01:27 AM
kris69fl kris69fl is offline
For the 88 accord drivers out there. If your car is a fuel injection and the idle isn't raised up at cold the fast idle valve is not working needs to be cleaned or coolant isn't bleed out. The valve gets dirty and the orings dry up! If the car dies out on a stop almost every time the egr valve needs to be cleaned I use berryman carb cleaner just soak the bottom part not the diaphram!. also check if there is any codes the cpu in under driver seat in back do at night pull the tab and count the blinks. the at sensor is code 10. Fast idle valves are getting hard to find udjust by turning with screw driver on one side the idle. use lube so the screw driver doesn't wear the tabs, due to being dirty. these are the big key elements, besides keeping the valves adjusted. .010 to .012 on exhaust and .005- .007 intake.
1988 honda accord dx fordjay16 Accord/TSX/Accord Hybrid 4 07-20-2003 12:23 PM
