Old 11-01-2003, 04:23 PM
shadetreemechanic shadetreemechanic is offline
cut off and stalling
my 1999 Blazer will cut off and stumble with no warning at no particular pattern. It will also stall or cut off at a stop light or stop sign, again, no warning or pattern. It is sporadic and driving me crazy. I replaced the map sensor and fuel filter but the problem remains. I'm all ears. Thanks
Old 11-02-2003, 08:16 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: cut off and stalling
First thing you will need to know is if the truck is loosing fuel or spark.
Fuel systems on those trucks are known for giving some problems...check the fuel pressure..needs to be about 60 psi.
Also while the engine is running, wiggle the wires to the coil...sometimes they will break inside the insulation and cause intermittant stalling concerns.
There were some trucks with intermittant ignition switches causing problems also.
The most important thing is to perform a little diagnosis before you spend any money on a part that may or may not fix your problem.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-05-2003, 10:01 PM
hoppy3388 hoppy3388 is offline
also gm tech and i would also check the ground f0r the fuel pump it goes to what they call a ground comb and i have seen them melt.2 dr are located behind the rear bumper not sure where a 4dr is. also posible crank sensor it the bottom of the front cover
Old 11-26-2003, 10:29 PM
brockhaus ronald brockhaus ronald is offline
Watch your instrument lights. When you turn the key to on, you get an array of lights, air bag, anti-lock etc.. If you do not see these when you stall or it when won't start, the ignition switch module is bad. Look through these post subject there are some good instructions how to change it. I just did it myself.
98 sunfire cutting out and stalling jcamry General Discussions 1 11-28-2009 05:05 PM
98 3cyl Metro Randomly cuts out and stalls NHxj4x4 Metro 13 06-19-2008 08:16 AM
spedo goes crazy and gas peddle cuts off and on:help me plz 99ramair Grand AM 2 01-09-2007 11:25 AM
86 Ranger cuts off and on nto02 Ranger | Courier 3 05-28-2005 07:18 AM
96 accord a/c starts cold but fans cut off and blows warm joeramirez Accord/TSX/Accord Hybrid 5 06-15-2004 06:42 PM
