Old 11-01-2003, 03:34 PM
Shelbrain Shelbrain is offline
1999 Blazer - Broken Rear Hatch
Does anyone know how to fix a rear hatch on a 1999 Chevy Blazer? I don't even know how to get at it. I push the button and the window usually opens, but now nothing.
Old 11-02-2003, 08:10 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 1999 Blazer - Broken Rear Hatch
You will need to remove or particially remove the rear panel to get to the mechanism (this will be difficult if you can't get the door open)
If you can pull back the panel enough to release the hatch by hand, then you can open the door and remove the panel completly.
If I remember right, you can just pull up the top of the panel and roll it back just a bit.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-02-2003, 01:31 PM
I can get the back door open, but I can't open the window in the top half. What part would I need to replace once I get the panel off. Is getting the panel off easy (I didn't see any screws).
Old 11-03-2003, 01:10 PM
duongladdee duongladdee is offline
I have a 1997 Blazer LS and the same thing has happened to me!
It worked when we were at the store loading groceries, but would not open when we got home. I can't afford to take it in and I believe I could fix it myself, if I just knew how to get at the latch? I can't open the bottom (tailgate part) without opening the hatch (glass) first. I mean, it does unlatch from inside the car, but the glass holds it up. Is this the same for you as well? I thought maybe the carpeted panel came off, but when I tried the edges it's all glued.
dee
Old 11-07-2003, 06:24 AM
Yes, that is the problem I am having. I cannot take the carpeted part off to remove whatever is broken.
Old 11-10-2003, 12:40 PM
mobzs's Avatar
mobzs mobzs is offline
Send a message via MSN to mobzs
Lightbulb rear hatch
a flat tip screwdiver, phillips screwdriver and your hands is all you need to open both the glass and hatch. i just replaced the lock on my hatch this weekend. work the flat tip on the glass latch you will be able to release the catch and open the glass. now with that out of your way, grab the center of the trim piece and pull back an inch(any further and you'll break it just like i did). stick you flat tip in the gap and with a downward motion push the lever. there is only one lever that will move up\down. that will get your tail gate open. there are 6 phillip screws(if it's like mine) and the trim piece comes off. then there is a cover plate over the all the good stuff the bolts are metric. that should give you access to what you need to do. hope this helps.
Old 11-14-2003, 01:34 PM
golf32902 golf32902 is offline
one word......... EBAY
Old 02-13-2005, 06:55 PM
bfln8bv bfln8bv is offline
Send a message via Yahoo to bfln8bv
Broken Hatch
Fixed it! To open the hatch, use an allen wrench. From inside the car, take the allen wrench and insert it between the glass and the panel just LEFT (looking from inside) of the locking mechanism. Turn the allen wrench so that the "L" is pointing toward the front of the car and push down. What you are doing is pushing down on a lever that releases the catch. Its pivot point is about 1 1/2 inches from the mechanism toward the right side (left if inside looking back at the hatch) From the pivot point, the lever extends to the just behind the latching mechanism, so there;'s plenty of lever to get the allen wrench to rest on, then push down - glass should open.
Then remove the handle for the tail gate, and one screw on each side of the tail gate to remove the panel. Once out, lift the panel from the top of the tail gate, there are clips (3 or 4) that are made to pull out.
Then remove the metal cover on the panel, 8 or 10 tap bolts. You'll see a broken blue plunger. Take off the remains of the blue plastic, peel back the rubber on the solenoid and take a cable tie from the plunger to the butterfly mechanism that trips the latch. Any problems, email me with your phone number. You may email me on two different days because my spam filter will put your mail in my junk folder. I reveiw, but don't always pick up legitimate emails.
1999 Sienna rear hatch broken! Can't open! Chuck Paskovics Sienna 77 02-01-2017 02:53 PM
92 chevy blazer s10, rear hatch? mybigredford Problem Diagnosis 10 12-11-2006 06:46 AM
91 Jimmy rear hatch broken cjohnson71 Jimmy 0 07-31-2006 07:50 AM
1999 Chevy Blazer rear hatch albertconnie Blazer 2 06-15-2004 06:17 PM
