Old 11-01-2003, 12:59 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Another quiz for you all.
OK folks, quiz time again! I found this one posted on another site and figured let's see if people here can answer these questions?
1. The '83 Mustang GT came with an SROD four-speed manual trans. What does SROD mean?
2. Mustangs from '79 to '95 were all available with a V8 engine. It was a 302(or 5.0) for 15 of those 17 years. Which two years was the 302 not available, and what size was the engine.
3. During the 79-93 run of Fox Mustang production, there was an upgrade from a 7.5" to an 8.8" rear end. What was the first year for the 8.8" and what gear ratios have come from the factory in Mustangs since then?
4. What was the size of the Throttle body on '86 5.0 Mustangs?
5. The '86 Mustang had restrictive cyclindreheads that make great paperweights. What is the casting found on thses heads?
6. The largest optional wheel for 79-84 Mustangs was an odd ball size. What was the size of the wheel in inches, and what was the only make of tire that would fit it?
7. What was the last year of forged pistons in a 5.0?
8. True or false? The Boss 302 Mustangs of 69 and 70 came with huge intake valves in the Cleveland-style head. There was no change in the size of these valves between the two years.
9. If there was a size change in the valves, what was in the 69 and 70 Boss 302s?
10. True or false? Ford's nearly indestructable 2.3L four-banger uses hydraulic valve lifters.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 11-01-2003, 02:28 PM
fastang fastang is offline
Send a message via MSN to fastang
hey i got #1...
SROD stands for,Single Rail Overdrive. the SROD was a 4 speed manual, it was replaced with the stronger Borg Warner T-5 5 speed. people use it today in their rods, if they dont drive hard.
Old 11-01-2003, 02:42 PM
2.the two years that the 5.0s were not an option are, 1980 n' 1981. the largest engine option was the 4.2L with only 119hp!
Old 11-01-2003, 05:22 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
#3 86 I belive if not 85'
Sidenote: 83GT's also came with T-5's 1/2 way through the production year.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-01-2003, 09:26 PM
venom800R venom800R is offline
#ten is true, other than that im not a big five oh afficianado, but my dads got a 2.3 in his ranger
Sex should be like a riced out Honda, slow, obscene, and loud enough to wake the neighbors - unknown
Old 11-02-2003, 05:01 PM
Trigger351's Avatar
Trigger351 Trigger351 is offline
I say its true.
The boss 302 definately had big port Clevo type heads
MUSTANG powered by FORD
http://www.tmaauto.com/
Old 11-02-2003, 05:35 PM
Los Los is offline
Send a message via AIM to Los Send a message via MSN to Los
Re: Another quiz for you all.
1. Single Rail Overdrive
2. 80 and 81, german 255.
3. uh... 87, with 3.08s, which were changed to 3.27s in 99.
4. 55cm?
5. Not E7TE.
6. 16.5? Cooper?
7. 92. 93 introduced the Hyperutectic pistons.
8. true
9. 1.8 and a 2.02
10. true. Ford is cheap.
Los
Texas Racing Scene.com
Lawton Racing
Old 11-02-2003, 09:01 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
i think #4 was 55"mm" man, lol. i thought they dropped the 8.8" in the second the EFI's were released in 86?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 11-02-2003, 09:10 PM
HiFlow5 0's Avatar
Stanger
These are good guys. I see some good answers, but I do see some wrong ones. I'll post the results in a day or so.
-2013 Ford Flex
-1999 Ford F150
Old 11-07-2003, 06:23 AM
HiFlow5 0's Avatar
Stanger
Re: Re: Another quiz for you all.
Looks like you guys all gave up on this quiz. Ok well here's the answers just incase if anyone was curious.
Here's the answers.
1. Single rail overdrive
2. 1980 and 1981, 255ci
3. 1986, 2.73, 3.08, 3.27, 3.55
4. 58mm
5. E6SE
6. 15.3x5.9 inches, Michelin TRX
7. 1992
8. False
9. 2.23 in 69 and 2.13 in 70
10. False
-2013 Ford Flex
-1999 Ford F150
Old 11-07-2003, 07:38 PM
i feel like an idiot
The Special classes: A quiz for you! JekylandHyde Non Specific 7 07-11-2006 01:22 PM
Another Sunday Foxtrot For You All MunG35 COMPLETELY off-topic 6 05-26-2006 01:54 PM
Here's another Vette for you Tonio7 pcmodeler WIP - Street 14 08-25-2003 04:45 AM
