Old 10-30-2003, 07:27 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Deeper Tamiya Candy lime green spray...
Does anyone have any ideas on how to get a deeper finish with tamiya candy lime green spray. I was thinking backing it with gold, Any body have any other ideas?
Old 10-30-2003, 08:43 PM
freakray freakray is offline
AF Modelrater
Gold would probably work.
You could also try putting an undercoat on of another shade of darker green, that should darken the candy lime green significantly.
AF User Guidelines
Old 10-30-2003, 09:07 PM
Camber's Avatar
Re: Deeper Tamiya Candy lime green spray...
Thanks! I did'nt think of that
Old 10-30-2003, 10:40 PM
jgmodelcars's Avatar
jgmodelcars jgmodelcars is offline
Send a message via AIM to jgmodelcars
you could do in this order: primer, silver, transparent green, tamiya candy lime green, then your clear. That would make it look pretty nice!
My real name is Justin don't be afraid to use it.
Old 10-31-2003, 12:22 PM
Biting_Point's Avatar
Biting_Point Biting_Point is offline
Candy Lime Green is a metallic colour.. either back it with a metallic grey.. or can try orange too..
Current Projects:
RC211V Camel 2003 - Finished!
RC211V Fortuna 2002- 70%
RC211V Pramac 2003 - 65%
RC211V Telefonica 2003- 25%
RC211V Valencia 2003 - 25%
RC211V Repsol 2003 - 10%
Old 10-31-2003, 01:22 PM
V1nce V1nce is offline
from my understanding of candy paint (after discussing the subject at the paint fabicators). candy paint is just a die, therefore the darkness of the color is created by the number of layers of paint laid down. the back ground color should also be the correct color for the candy. that was with automotive paint dont know weather the tamiya stuff is the same
Old 02-09-2014, 08:44 AM
Jarkko Antikainen Jarkko Antikainen is offline
I found out that using Tamiya Silver Leaf spray as a base for Tamiya Candy Lime Green creates an interesting, gold reflecting candy effect.
Old 02-09-2014, 11:11 AM
lemansnut lemansnut is offline
I did a paint job a while back with Tamiya Mica Red over a gold base, then a coat of clear red followed by a couple coats of clear and it came out very much like a candy finish. Don't know why the same wouldn't work for green.
Mike
Old 02-09-2014, 05:34 PM
da_ashman's Avatar
I once sprayed a light coat of Candy Lime Green over a gold base, had an awesome effect, gold highlight with green in curves etc.
Tamiya's "Candy Lime Green" isnt a true candy, its more a metallic green as a true candy is a dye based colour.
For a darker shade you could try spraying over black or dark grey but the more coat you put on the more its going to look like the lid.
Old 02-09-2014, 07:53 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Personally, I put it on really thick. Often one can isn't enough, but nothing looks deep like making it really, really deep. My rule is if I can still see panel lines, it gets another coat!
PHOTOBUCKET SUCKS
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
