Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-30-2003, 10:54 AM
Syyd Syyd is offline
'94 Bonneville Intermittent Stall Issues
I bought a 1994 Bonneville last November, in the past year I have continual problems with stalling, in cruising situations (65mph) and after, the car will not start, and then bingo, it comes to life again.
I have had the fuel pump, fuel tank, starter module, sensors replaced, as well the entire tumbler and ignition replaced, and then they told me it was a wire. I drove it off the lot, hit the highway and BINGO! It started stuttering, and the warning bell came on.
Any advice from anyone, I dont want to buy a new car till spring, and, I noticed this intermittent stalling issue seems to be an overall Bonneville/Pontiac thing (my grand prix did the same thing).
Thanks.
Syyd
Old 10-30-2003, 02:03 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: '94 Bonneville Intermittent Stall Issues
Most important and hardest part of intermittant problems is duplicating the complaint and narrowing down what system is causing the problem.
Read some of my replies on other posts about stalls and no-starts......(I need to have some stock replies handy instead of typing the same thing over and over again)
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 01-10-2004, 01:51 PM
t-HHH-eGame t-HHH-eGame is offline
Send a message via AIM to t-HHH-eGame
I had a problem like this and fixed everything we could think of. It turned out to be a melted wire harness under the carpet by the driver's door. Direct saudered the wires and haven't had a probelm in 6 mos. (cross them fingers)
Old 01-16-2004, 05:31 AM
bridget36907's Avatar
bridget36907 bridget36907 is offline
did you replace the crank sensor?
2005 Grand Prix GT
3800
1995 Chevy Caprice
LT1 5.7
1986 Dodge Ram
Old 09-06-2010, 09:58 AM
clutch492 clutch492 is offline
ASE Master Tech
Smile Re: '94 Bonneville Intermittent Stall Issues
There are ground wires that are all connected together at the drivers door sill. Pull the carpet back (right at the door) and you will see a black connector with about 8 black wires going to it. This is the common tie that hooks all the grounds to a main ground wire. There is a metal tab in that connector that links all the wires together. Pull off the black cover, remove the metal tab, clean all corrosion from this metal tab, re-install and your problem is cured. There is another common ground like this on the passenger side, but the drivers side is where the fuel pump ground links in. This is usually the problem.
'95 Lincoln intermittent stalling issue TexasBee Town Car 4 10-14-2010 05:59 PM
94 Bonneville either stalls while coasting or idles high parnellij Bonneville 6 09-27-2009 10:08 PM
2000 2.4 Stalling Issues SteveFord26 Cavalier Problem Diagnosis 7 09-11-2009 08:56 AM
2000 jgc stalling issues sofarinthehole Grand Cherokee | Grand Cherokee SRT8 0 04-23-2009 08:45 AM
93 bonneville se stall issues allbusiness Bonneville 3 12-13-2007 01:49 AM
