Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-09-2007, 03:32 PM
allbusiness allbusiness is offline
Send a message via AIM to allbusiness
93 bonneville se stall issues
Car ran fine and suddenly stalls out. Doesn't want to start and when it does it stalls immediately. Changed plugs and wires, fuel filter, oil and filter. Once the car gets started it begins to run rough and won't stay running. Checked the fuel pump and it works. Cleaned throttle body and egr valve. Has no engine light on and no codes when plugged into a diagnostic. Haven't checked fuel pressure. Could it be the mass airflow sensor, fuel pressure regulator?
Old 09-10-2007, 05:00 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 93 bonneville se stall issues
Welcome to AF!!
Change the crank position sensor on you car and it should cure the problem. The problems you are experiencing are the classic signs of one going bad and they will not throw a code until the completely die.
One other thing check and make sure the security light is not coming on when this happens could be an issue with the Pass Lock system too.
Old 09-18-2007, 05:01 PM
we changed the crank sensor as you suggested and the car still runs bad. Also tried the iac valve. When car runs it backfires and runs rough still, could the timing have jumped a tooth? It also makes a 'wooshing' noise just before it stalls out. any other suggestions would be helpful.
Old 12-13-2007, 01:49 AM
cheap_jeep88's Avatar
cheap_jeep88 cheap_jeep88 is offline
try cleaning the ground strap under the coil pack i kinda had the same problem with mine. give it a shot its free cheap and simple
