Old 10-29-2003, 12:21 PM
setatenken setatenken is offline
[D] and D what is the difference?
on the transmission there are two drive modes. one [D] and D...
how are they different?
Old 10-29-2003, 07:12 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: [D] and D what is the difference?
D is Drive, in other words, 3rd gear
[D] is Overdrive, 4th gear. I think your gear selector should read
P R N [D] D 2 1
you should select overdrive, because in drive, your car will not shift into fourth, causing higher rpms, and burning more fuel. You should only use drive if you are towing, which few people(*cough* tman *cough*) try with a Buick Park Avenue.
Old 10-31-2003, 01:29 PM
Crang Crang is offline
I thought, the "Over Drive" is not actually a 4th gear but a different clutch pattern that engages in the transmission. Buicks also have the Torque Converter lockup which knocks off a few hundred RPM with or without the Over Drive.
Old 10-31-2003, 05:33 PM
tman's Avatar
Pimpin' ain't easy
OVerdrive is 4th gear, not some clutch pattern, the car has no clutch!
Old 11-01-2003, 06:11 PM
thanks guys. im getting so much help here
Old 11-01-2003, 07:38 PM
Well the service manual shows clutches in the automatic transmission, but I was not refering to a clutch like a manual.
Old 11-02-2003, 12:08 AM
tman's Avatar
Pimpin' ain't easy
looking at your post, you said "clutch pattern that engages" Sounds like a fancy way to say a different gear to me.
whats the difference between the 4t40e and the 4t60e aptyk88 Grand AM 1 01-13-2008 05:34 PM
Whats the difference between the 68 chevelle and the 68 beaumont????? thetaz_31 Chevelle 5 07-22-2006 07:34 PM
whats the difference between the ecu and the eprom? BlackShadowTSi Off-Topic 11 06-15-2004 01:23 PM
Which sr20det should i get and whats the differences? caper 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 22 08-10-2003 11:36 PM
whats the difference in the 4th gen si vtec and the vtec Got Boost? Prelude 10 08-31-2002 04:31 PM
