Old 10-29-2003, 12:34 AM
norcalmike norcalmike is offline
Smile 2002 Silverado Z71 keyless entry
I know its probably already on here somewhere but I cant find it. Does anyone know the process for programming keyless entry remotes on a 2002 Silverado Z71? My truck came with only one and I bought 2 more on eBay that have the same part numbers. Thanks in advance for any help. Mike
Old 10-29-2003, 04:48 AM
cobra1 cobra1 is offline
Transmitter Programming Procedure (Method 1 - No Tools Required)
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Old 11-02-2003, 07:29 PM
Smile Re: 2002 Silverado Z71 keyless entry
Thanks Cobra, Worked just like you said, I really appreciate the help.
Old 12-20-2003, 09:04 PM
pt11070 pt11070 is offline
hi,
I have a 2001 silverado and I followed the instructions given but I never get pass "the doors will lock and unlock to confirm the program mode" phase. can you help?
Old 12-22-2003, 01:14 AM
Re: Re: 2002 Silverado Z71 keyless entry
Originally Posted by pt11070
hi,
Sorry I cant help you. Maybe somone else will reply.
Old 12-22-2003, 02:37 AM
my service information cd's say that the procedure is exactly the same for 2001 as it is for 2002.
be sure all doors are closed and that its followed exactly.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
Keyless entry for 2002 will operate slider but not locks?? liss567 Montana/Montana SV6 4 09-28-2010 10:40 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
2002 Silverado Z71 Blower Motor Removal bparks6982 Silverado 1 01-13-2007 03:31 PM
2000 Z71 Keyless Entry programming NVBigRed Silverado 15 08-30-2005 01:41 AM
