Old 10-28-2003, 11:05 AM
zee 400 zee 400 is offline
cracked block i think
I took water pump off and it is fine but i noticed residue on it. so i took a coat hanger and stuck it down the right side of the block and it came out oily. is that a cracked block or a blown head gasket.
Old 10-28-2003, 12:07 PM
Sexy beast's Avatar
Sexy beast Sexy beast is offline
Banned
Only one way to know, take it to da machine shop!
Old 10-28-2003, 12:31 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
More then likely it is a blown head gasket......that would definately explain your overheating problem as well. A cracked block is very hard to do in the 6. Unless of course you live in colder climates.
Old 10-28-2003, 12:36 PM
Sexy beast's Avatar
Banned
I am not trying to step on anyone's toes...but what if he...changes the head gasket, and then... the engine continues to leak? It would be a lot of work and money on parts for nothing. Is there a way to be sure?
Old 10-28-2003, 01:05 PM
well....if he has the money he can always take the block over to have it hot tanked and then magnafluxed to look for cracks.....but that is costly.....
Old 10-28-2003, 02:10 PM
grizzlybear310 grizzlybear310 is offline
Send a message via MSN to grizzlybear310 Send a message via Yahoo to grizzlybear310
Re: cracked block i think
Have you checked to see if you have any water in the oil?
What about oil in the water?
What does inside the radiator neck look like?
Was/is it white smoking out the tail pipe?
You might want to start by taking the head to the maching shop and have them check that first.
Did it try to push the water back out when putting it in it, as in blowing it back at you?
Old 10-29-2003, 12:46 PM
cracked block
Yes it does shoot the water out as i try to put it back in and my water is considerabley clean but i did just change my head gasket and all of you are going to think i am very smart when i did this. my torq wrench broke so i just tightned them down as much as i could. sorry. that is probably it. ha ha. man i am smart.
Old 10-29-2003, 01:22 PM
Sexy beast's Avatar
Banned
Re: cracked block
OUTRAGEOUS!!
Old 10-29-2003, 01:40 PM
now thats a good way of cracking a head! I6 need to be torqued down in a specific pattern and to a specific range! Id go and borrow one just to make sure!
Old 10-29-2003, 03:35 PM
capt. apathy capt. apathy is offline
not to be the one to drag out and point to the obvious (or what should be obvious) but the point of a torq wrench is to stop you from putting too much torq on the bolts.
btw- just for future reference a new torq wrench is generally cheaper and a lot less hassle to replace than a new head, or removing a broken bolt from the block.
Old 01-06-2004, 06:28 AM
SG-MALiCE SG-MALiCE is offline
Cracked Block?
Funny you guys should be talking about 'cracked blocks'.
I think I may have that same problem. I assumed that I had plenty of time due to the warm-rainy weather here in Canada, BC. However, mother nature pulled a nasty twist on me and turned our rain into snow! I neglected to add Anti-Freeze to my water before the freeze hit. So when I went to start my car, the belts would burn on the pulley's due to the frozen water pump. So I consulted some friends and got some opinions on what to do. I was told to take off the belts and run the motor without them in order to 'melt' the water and free up the water-pump, so I did that. It worked. As soon as the waterpump began to circulate (spin), I then turned off the car, and put the belts back on and tightened everything up.
I then continued to run the motor in order to melt the remaining ice within the hoses and radiator. I was having success, but as the motor heated up, I noticed two distressing things.
1. A small pin-hole fracture formed in the top of my radiator.
2. Steam was rushing out of my breather cap on my valve-cover, (driver's side).
I checked under the engine block to make sure that there were no water leaks, and it was water-tight, no leaks. So that would indicate to me that the "frost-plugs" are still intact and didn't pop. I then checked the oil via the dip-stick. I noticed a creamy-grey colorization on the dipstick, which indicates to me that water is somehow mixing with my oil.
Now, I'm an optimistic (and very BROKE) individual. I am hoping that this is nothing more than either water/condensation evaporating from the engine block, or merely a blown head gasket.
Does anyone have any advice or assistance they can offer?
Old 01-06-2004, 11:05 AM
here's a couple bits of advice.
1. you live in canada & drive a rig that runs very close to the boiling point in summer time. so unless you are trying to flush out the cooling system that thing should never have plain water in it.
2. start shopping for a new engine, or at least a new block. you might get lucky and 'just' need a new head.
3. slap your 'friend'. next time you get in this spot, push it into a garage and make sure it's completely thawed out before starting it.
they way you did it if you didn't have a cracked block from the freezing you'd have one by the time you got to operating temp. assuming you are extreamly lucky and did no damage as you melted the ice in the engine, I wonder how much pressure you built up in the engine as the engine heats up and melts the water (but cant circulate because the radiator and hoses are a block of ice), so the ice turns to water, turns to steam. not a pretty picture.
Old 01-07-2004, 11:11 PM
Ok, here's whats happened now.
I succesfully managed to thaw the motor to the point where I was able to put in Anti-Freeze and circulate the water/AF mixture. The Steam from the breather is now gone, and it would seem that the pinhole on the radiator is no longer visible (but still exists) at running temperature.
There are still no leaks from under (or around) the block, it's water-tight. Everything sounds normal, no clanking, friction, ticks/knocks, no steam, idling nicely.
Now, I have been monitoring the oil at this point and for the last few days. I have noticed that the creamy-chocolate color has now got a "dark green" coloration to it. Hardly noticible though, you really have to squint under good light to see it. Which at this point would indicate that the anti-freeze that I just recently added to the motor, is somehow mixing with the oil. Cracked Water Jacket or possibly Blown Head Gasket?
Anyway, I also checked the Radiator periodically, and I noticed that the oil isn't mixing with the water. The Water/AF mixture in the Rad is completely clean. So, after all these tests, I am still not sure what this could be. It could be that the water/moisture got into the oil-supply, and whats sitting in it now is just residual, otherwise -- why isn't the radiator water/AF mixture contaminated with oil yet?
So in light of that, I decided to take off the driver's side valve-cover to closer inspect the head. I didn't notice any damage, but there was a residual chocolate-milk colorization to the oil of small proportion underneath the valve cover and inside the head.
So here is what I know for certain....
1. No leaks of any kind/any fluid from any area of the engine/tranny.
2. The water/AF mixture is completely clean after hour(s) of running the vehicle.
3. The dipstick oil-level is the "same" level each time I check it, but of a milky-chocolate with the slight dark greenish colorization to it.
4. No un-usual sounds or running condition, everything appears 100% normal.
So with all of that, could this just merely be a blown head gasket that's allowing the water to enter the oil supply, but preventing the thick-oil from entering the water supply? Or some variation?
Old 01-08-2004, 06:51 AM
yep, the water/coolant is definately mixing with my oil. I'm sure there is a leak somewhere. Hopefully a blown gasket of some sort.
Old 01-08-2004, 12:55 PM
I'd think your guesses of cracked water jacket or possably blown gasket are the most likely suspects.
don't run it with that water in the oil or your problems will multiply.
Cracked block? BresRodeo Rodeo | Passport | MU 7 04-25-2009 01:02 PM
cracked block? Feeenxxx General Discussion 1 03-17-2009 06:09 PM
Ever heard of "water glass" for a cracked block?? OldBlue72 Impala | Impala SS 2 02-23-2004 05:46 PM
possible cracked block on 93 ranger tkjskj02 Ranger | Courier 3 02-22-2004 03:06 PM
Cracked block or bad head gasket? Oil in radiator. spayordie '88 - '91 Civic | CRX | Wagon | Shuttlee 7 11-11-2003 12:44 PM
