Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-30-2003, 08:53 AM
tkjskj02 tkjskj02 is offline
possible cracked block on 93 ranger
I Have Water Leaking From Under The Motor And Everyone Keeps Telling Me My Block Is Cracked But I Have No Water In My Oil. Is There Anyone That Can Give Me Some Suggestions Please. I Have Put Block Leak In The Radiator And It Is Suppose To Seal Blocks,heads, Etc. But Has Not Worked.all Help Would Be Appreciated. Thanks
Old 12-04-2003, 08:59 PM
freezin-mybunz-off freezin-mybunz-off is offline
Re: possible cracked block on 93 ranger
check your water pump, if it was leaking there, it might run down and drip underneath. also be sure to check all your hoses and seals (thermostat housing, ect) and your coolant drain plug on the bottom side of the block.
Old 12-27-2003, 09:11 AM
Katoom Katoom is offline
There is a weep hole on the bottom side of the water pump. This is most likely the source. If it is, replace the pump...and flush that crap out of your cooling system too. It's more trouble than it's worth.
Old 02-22-2004, 03:06 PM
Thanks for the help....it turned out to be a freeze plug. i replaced it and it works great.
Cracked block? BresRodeo Rodeo | Passport | MU 7 04-25-2009 01:02 PM
cracked block? Feeenxxx General Discussion 1 03-17-2009 06:09 PM
cracked block i think zee 400 Cherokee 17 03-07-2004 08:17 AM
Is this possible? Cracked Block) belmont3 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 02-04-2004 09:25 PM
Cracked block or bad head gasket? Oil in radiator. spayordie '88 - '91 Civic | CRX | Wagon | Shuttlee 7 11-11-2003 12:44 PM
