Old 10-27-2003, 05:25 PM
SlowHatchGrL's Avatar
SlowHatchGrL SlowHatchGrL is offline
Send a message via AIM to SlowHatchGrL Send a message via Yahoo to SlowHatchGrL
OBDII Into 88-91 Hatch or Rex!!!!??!!
Aight, does anyone have any info on doing that swap??? I have not found anything!! I need some help!!!!!!!
Texas Raceway
Old 10-27-2003, 08:07 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
Do you mean converting the car to obdII? If you just mean swaping in an obdII motor it can be done really easy...I just put one into my boys rex and the only problem we ran across was getting the radiator fan to come on.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 10-28-2003, 12:25 PM
I mean swapping the engine in. I mean some peeps are telling me you have to switch it over to OBDI. But I thought you could just use the 96+ engine wiring harness and ecu!??
Texas Raceway
Old 10-28-2003, 12:31 PM
91civicDXdude's Avatar
Re: OBDII Into 88-91 Hatch or Rex!!!!??!!
you could convert the car to OBD1 and then get an OBD1->OBD2 conversion harness.. i belive they can be had. I know that with an OBD2 car you can convert to OBD1 with a harness, so the wiring is the same..
If you went the route of swapping the entire electrical harness out of the car, sure the engine would work as would the ECU, but then you'd come acorss the problem of all the headlight/tailight dash wiring would be different.
Old 10-28-2003, 01:15 PM
Ok, what about just going to OBD0?? Using a PR4, 90-93 wiring harness, and 90-93 dizzy.
Texas Raceway
Old 10-28-2003, 01:17 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Why not just keep your car Pre OBD? Do you really need to go OBDI? Usually the bonus of doing that is if you live in California, where emissions laws are tough to get around.
OBDI is overated.
Old 10-28-2003, 01:19 PM
kris's Avatar
Yes, you can stay OBD0. I assume its a b series swap? Just a fwi though, only the 90/91 teg is OBD0.
Old 10-28-2003, 08:16 PM
Yes, it's a B18B1.
Texas Raceway
Old 10-28-2003, 08:18 PM
90-91 = obd0
92-93 = obd1
94-96 = obd1
Old 10-28-2003, 09:28 PM
kris's Avatar
Originally Posted by 91civicDXdude
90-91 = obd0
92-93 = obd1
94-96 = obd1
uh, yeah, that's pretty much been established at this point.
Old 10-29-2003, 12:05 AM
Re: Re: OBDII Into 88-91 Hatch or Rex!!!!??!!
obviously not
WTS: wings west rs front bumper for a 88-91 hatch 90civichbsi '71-'87 Civic | CRX 15 06-17-2004 06:44 AM
88-91 hatch altezzas on a 88-91 sedan? bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-14-2003 11:13 PM
88-91 hatch tail light conversion Jetts '88 - '91 Civic | CRX | Wagon | Shuttlee 18 12-18-2002 12:01 AM
jdm b18c-r into a 88-91 hatch tenzoracerevovii '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-08-2002 12:39 AM
