Old 10-27-2003, 04:41 PM
pontiacgtp pontiacgtp is offline
Question RPM problems in park or neutral
My 98 GTP will only rev up to 4000 RPM while in park. While I drive, it performs fine up to the redline. I don't believe that this is normal. Maybe fuel filter or something on the fuel line? Suggestions are welcome,Thanks.
Old 10-27-2003, 05:13 PM
BOOZER BOOZER is offline
Re: RPM problems in park or neutral
The PCM will cut fuel delivery, there is no problem, so don't try to fix it.
WHY ARE YOU TRYING TO SPIN AN UNLOADED MOTOR HIGHER THAN THAT ANYWAY?????????????
Old 10-27-2003, 05:18 PM
gtp 2000 gtp 2000 is offline
dont rev high while not in gear
dont rev that baby to high . you are asking for big trouble if you rev her up while in park or neutral
Old 10-27-2003, 06:09 PM
Lightbulb
Thanks BOOZER, I just wanted to find out if that was normal or not. By the way, I was just testing it to make sure the engine was running smoothly. I don't normally do that.
Nissan Cefiro - Idling/driving rpm problem fnasir Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 9 10-01-2010 10:35 AM
Seems when i'm sriving im in neutral, RPM shoots up but car goes nowere. airngu3 1st Gen 95-99 3 06-19-2009 08:11 AM
Rpms dip in Neutral into_despair SC/SL/SW 4 05-30-2009 02:02 PM
Increased RPM while in neutral or with clutch depressed 2001cblazer Problem Diagnosis 4 01-28-2008 04:09 PM
Park-neutral switch on 89 4x4 Toyota w/ intermittent starting problem jake jake Pick-Up 3 03-17-2007 08:35 PM
