Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-14-2007, 05:03 PM
jake jake jake jake is offline
Park-neutral switch on 89 4x4 Toyota w/ intermittent starting problem
someone told me that the 2 most common problems that cause an intermittent starting problem on an 89 4x4 V-6 Toyota [mine is automatic, 3VZE engine] are (1) bad battery cables, and (2) a defective park-neutral switch.
where is the park-neutal switch ??? and what does that part do, and why would it cause an intermittent starting issue?
Old 03-15-2007, 12:46 AM
KimMG KimMG is offline
AF - Advisor
Re: Park-neutral switch on 89 4x4 Toyota w/ intermittent starting problem
It prevents you from starting in gear.
Old 03-15-2007, 07:36 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
I'm fairly sure it's in the base of the shifter assembly (but on some vehicles it is located on the transmission where the shifter linkage attaches). If it gets loose/out of alignment it will not let you start the engine.
To find it check a service manual (see service manual sticky at top of main page).
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 03-17-2007, 08:35 PM
do you have to replace the whole shifter to replace the park-neutal switch, or is the park-neutral switch just a tiny item in the park-neutral shifting assembly?
anyone have any idea what it costs to change the park-neutral switch on 89 4x4 toyota V-6 automatic?
