Old 10-27-2003, 03:09 PM
Russell333 Russell333 is offline
transmission
If someone could please help me, the trans works good until I stop and it wont go back down to low gear so it will stall, if you gear it down to low it will do fine, sorry it is a auto trans, someone told me there is a chip or someting in there, if that is so can you buy them and can you put them in there yourself, thanks
Old 10-28-2003, 01:44 PM
pjfranco pjfranco is offline
transmission
My '96 Lumina won't shift out of first gear until the car is warm - then it works perfectly. The same is so with the speedometer & odometer.
Old 11-02-2003, 12:25 PM
A common problem on many General Motors cars is the Torque Converter Clutch fails to release and causes the car to stall when it comes to a stop. Most of the time it is a stuck Torque Converter Clutch (TCC) solenoid, but this is not the only cause of this problem. General Motors has issued a few Technical Service Bulletins (TSBs) relating to this problem. There is also a specific diagnostic procedure to determine the exact cause of the TCC problem.
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
h22 sh transmission used as a regular transmission h22 Prelude 1 07-31-2004 11:32 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
