Old 10-27-2003, 08:46 AM
zippersbs zippersbs is offline
Check engine light on
I have a 1997 blazer, 4wd, 4.3 vortec 72000 miles. The check engine light came on & I am getting a code of: P-0440 Evap Emission Control System Malfunction. Any solutions? The idle is real rough & kinda shakes the truck, boggy on take off, but, only sometimes. I have already replaced the, control module on the coil, fuel relay, pcv, & ignition switch. Thanks, Dan
Old 10-27-2003, 01:28 PM
roddy roddy is offline
Re: Check engine light on
Sounds like you have a problem with the EGR valve. I had the same problem yesterday and cleaned the EGR so it can close properly.
Good luck
Roddy
Old 10-27-2003, 01:40 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The P0440 code is for a gross leak in the EVAP system...(Usually this code comes up when the gas cap is left loose) But it can be caused by other things.
The only proper way to diagnos an EVAP system problem is to use an EVAP tester which injects smoke into the EVAP system and is veiwed under hi-intesity light
As far as the running rough, this may or may not be related to the code
Check for vacum leaks as a starter
The EGR sticking open can also cause a rough idle complaint. It's fairly easy to pull off and inspect.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
