Old 10-25-2003, 11:00 PM
Erdrick191 Erdrick191 is offline
Question 4g63 turbo relpacing 4g63 non-turbo
I'm just asking for help or a point in the right direction if ne one knows what i would need. I found someone selling a 90 gs turbo and i wanted to buy it so i could put the turbo system in my 92 eclipse gs. I know they both are the 4g63 engines, but i'm more concerned now on how it affects my ECU and if anyone knows the best way to rewire the ECU or are there special tools or devices that can regulate the sensors without messing too much with the ECU.
Old 01-27-2004, 01:58 AM
turbodohc20 turbodohc20 is offline
Re: 4g63 turbo relpacing 4g63 non-turbo
Cheaper to just buy a Turbocharged car from start.
Old 01-27-2004, 02:17 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Since the motor is basically the same layout as the turbocharged 4G63, it is possible to bolt up factory turbo parts from another car. However, with the higher compression, it won't be possible to turn up the boost enough to gain huge amounts of power. Obviously, the compression can be lowered, but it may just be cheaper and less labor intensive to go out and purchase a factory turbocharged DSM.
My friend has done this swap. Make sure you know every thing you will have to buy and do for this.
I will see if i can get some info from him...He is overseas right now but i will try.
Good luck
Old 01-27-2004, 03:35 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
jeez... would people just search before asking questions like that!!! i mean common its that easy!!! there has to be like a couple hundered threads that answer that question!
Old 01-27-2004, 08:44 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Telling people that they should have gotten a turbo car earlier doesn't help now. Just answer the question instead of telling him what he should have done. Stop living in the past.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
can i put a 4g63-t in my non-turbo galant? eagle2000 Galant 1 03-12-2006 08:44 AM
Turbo on a non Turbo sfenton311 General 11 11-09-2003 09:31 AM
Adding a turbo to a non-turbo engine.... Divine Wind Engine, Transmission and Drivetrain 1 10-18-2002 07:41 AM
diff between turbo z and non turbo z pedezilla 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 09-22-2002 04:00 PM
